AC Question
I got a freon charge but the gas was leaking and caused the cold air to leave real quickly.
The Mechanic put dye and said the hp hose and the hose going from the condenser to the compressor both have leaks. First question is: What is the name of that hose going from the condenser to the compressor, I want to order it new from the dealer. I already have a new HP hose sitting at home. Second question is: Can there be something else involved. According to him the compressor and the condenser are fine. My radiator was rebuilt recently and works fine. No vacuum or electrical issues either. Is there anything else that maybe involved? Thanks |
Re: AC Question
O-rings could be leaking. That was what I replaced and it has held since.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
Re: AC Question
Check the How-To Docs.
Glenn
"The only thing necessary for the triumph of evil is for good men to do nothing" Aaron Burke 1993 25th Anniversary Edition #63 of 301. R.I.P. Rojo 7/24/2008 She saved my life! 1997 Ebony Mica Pearl LSI. BLACKBERRY 1998 5-Spd Legacy GT Wagon in Glacier White: NUBURU 2005 Cadillac STS in Sandstorm Metallic: STORMY Veteran and farthest traveler of 1st SoCal2MuseumsMeet2010. http://www.subaru-svx.net/photos/user.php?RojoRocket |
Re: AC Question
Keith |
Re: AC Question
It must suck to be a shriveled up used car salesman looking old man that has nothing better to do than badger people on an internet message board.
Re: AC Question
Since I have never sold a car in my life, and spent the day mixing concrete while working on installing my new rod Iron fence, I doubt if any information on that would ever be useful to you... I will take a shot at your latest dilemma. Don't hold me to it but guess for you would be… Your reply should possibly be posted in the “NOT EXACTLY SVX” category! I am trying to quit, but it seems helping you seems to be my lot in life. Keith |
Re: AC Question
2009 Volvo C70 T5 2008 Volvo S80 V8 2006 Range Rover Sport 2001 Audi S8 |
Re: AC Question
Keith |
Re: AC Question
Back to the topic at hand, if you go through the trouble of replacing lines, just make sure you replace the o-rings too.
Re: AC Question
Not true.. Trevor is a quality person. You have never been my "object of affection" How funny... But... at least, you do have a sense of humor! I don't actually wait for you to post something... When I see something really stupid, I just look farther, and that "maniac" thing is attached to it. That name tells it all... Getting your jollies by criticizing a Minnie mouse picture? How un-American. Keith |
Re: AC Question
Stop it guys, this is getting old.
Re: AC Question
Thanks a lot, I'm ordering it tomorrow, I'm not to technical in that area, so I need to know which o rings specifically..
Should I tell the dealer the hose going from the condenser to the compressor and the o rings for the (from the)..... |
Re: AC Question
I guess he put it on the hoses after releasing the gas to see where it was coming out from and used a purple light to see the tares, It had quiet a few on both hoses...
Re: AC Question
Good luck! Keith |
Re: AC Question
Wow that hose is coming out to 150$ even after discount. Does anyone have that hose in good condition, or is it better for me to just get it knew?
