Old 07-29-2011, 02:20 PM
Re: wheel bearing failure
So you were towing the car with the axles removed?
Yes that would explain it...
Old 07-29-2011, 02:30 PM
Check and make sure you didn't just unscrew the axle nut!!!!
Old 07-29-2011, 02:41 PM
92_LSL's Avatar
92_LSL 92_LSL is offline
I know, It's very hard to believe.
But you ask for pics, and pics you shall receive.
I has teh FWD LS-L
Old 07-29-2011, 03:21 PM
92_LSL's Avatar
here's your pics
I has teh FWD LS-L
Old 07-29-2011, 05:31 PM
On a related note, if you roll the car with the lug nuts removed, the wheels may fall off.
Old 07-29-2011, 05:50 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Old 07-29-2011, 06:37 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
See, it wasn't even that long ago that I asked for pics, and **bam** there they are. Why can't everyone do this?
Old 07-29-2011, 06:51 PM
I know this is the digital era. take pictures and 30sec someone 4,000 miles a way can see it.
Old 07-30-2011, 12:13 PM
92_LSL's Avatar
For the sarcastic asses on here, the wheels were bolted on. my car Has 266,xxx miles on it, and that car NEVER made any sort or roaring noises. I'll have more pics of what happened soon.
I has teh FWD LS-L
Old 07-30-2011, 01:32 PM
It would seem the proverbial old dogs have been shown a new trick.
So towing the car on the ground with the axles removed may cause the bearings to slip out?
Old 07-30-2011, 01:39 PM
Sorry for showing my sarcasm, I know the wheels were bolted on. And if we would have been told in the beginning that you towed the car without the axles in place, we would have immediately known that the lack of axles was the problem and would have avoided all the questions about previous noises and other components.
The bearings were possibly good and silent before this. But the axle is what holds them together. At this point you can probably pull them back together and makes sure the outer dust seal is in place. But I see new front bearings in your near future.
Old 08-01-2011, 05:27 AM
Yes, no axles is what the problem was, not the wheel bearings, the axles ARE what holds the bearings together, so the bears Were fine....until you towed it with no axles in them, now they are surely bad.....
Old 08-01-2011, 04:17 PM
not the best idea, but in a pinch i have used the axle shaft and nut as a press to pull the bearings together. would plan on replacing them but at least then you could roll it around and probably drive it until your ready to replace them.
Old 08-02-2011, 10:51 PM
Green1995SVX's Avatar
It looks like it might be time for some new tires too!
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
