Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
Old 06-06-2011, 07:35 AM
processengr's Avatar
Gas milege increase from ECUtune 1AV1 chipset??
Anyone install LAN's ECUtune 1AV1 who had previously been running the 1V5 chipset?
What sort of improvements did you find? I am considering the upgrade....
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 06-06-2011, 06:25 PM
The Molinator
Re: Gas milege increase from ECUtune 1AV1 chipset??
I just switched from 1v4 to 1av1 about a week ago. I used regular with the switch ON when I had the 1v4 inserted. Now I use regular with the switch OFF. I don't notice any difference so far with the mileage.. . I get about 20 mpg regularly.. with a lot of country road driving commuting to work, and a moderate amount of city stop-n-go.. .
Thanks..
P.S. I installed a LAN MOD TCU also at the same time. I do feel a small performance improvement, but it's hard to tell if it's the TCU MOD which causes sportier later shifting.. and/or the chip.. ??? Probably BoTh!
Jim
