Old 05-25-2011, 08:44 PM
Lower the idle
How can you change the idle speed. i know with the carb motors u turn a screw.
Old 05-26-2011, 05:15 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Re: Lower the idle
Adjust the throttle cable to have more or less slack. I think they are 10mm nuts to loosen.
1995 Subaru Svx L / AWD
Old 05-26-2011, 06:55 AM
dcarrb dcarrb is offline
Re: Lower the idle
There isn't any sort of mechanical idle adjustment, and fiddling with the throttle cables is probably not such a good idea.
dcb
Old 05-26-2011, 07:56 AM
Cam Cam is offline
Re: Lower the idle
Messing with the throttle cable wont help. you can completely remove them and you idle will be the same. The idle on our cars is set by the ecu. Messing wih the set screws for your butterfly valves on the tb can alter idle, but it is not advisable since it changes the AFR
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 05-26-2011, 11:08 AM
Re: Lower the idle
if you are idling too high you might have a vacuum leak or your tps is misadjusted. the idle will change if you move the tps around.
Old 05-26-2011, 11:18 AM
Cam Cam is offline
Re: Lower the idle
I agree with 92snowmachine. What is your exact issue? Where is your engine idling at? There must be a reason you want to lower your idle.
Additionally, what year is the car and how many miles? What major maintenance has been done recently?
Cam
'92 Ls-L Dark Teal
Old 05-26-2011, 12:43 PM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Re: Lower the idle
Should be idling at 750 after a few seconds which is pretty slow.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 05-26-2011, 04:54 PM
Re: Lower the idle
I will have to check . i may have had the defroster or AC on...hummmmm
Old 05-26-2011, 07:15 PM
msvx95's Avatar
It's just a phase
Re: Lower the idle
Yes and no....I removed my throttlebody to replace a valve....I never adjusted my tps or had a vacuum leak and I now have a higher idle. I didn't adjust anything...so mine is a weird one that I'm still trying to figure out.
