#31
#32
Re: A specific question about the old "dipstick popping out" issue
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
#33
It is seriously a lot easier than you think. It's only tedious. I even did it with a regular non-angular wrench because I couldn't find my crow attachment.
#34
Can I pick one up at Autozone or should I stick to OEM?
#35
I don't believe there is any significant difference between either. It's only a weighted relief valve.
#36
OEM: 11810AA000
$6.86 .
#37
Yeah, more a matter of convenience than money. The Subaru dealer is further away and not open Sundays.
#38
Ok i have read thru this and I'm like I have that problem lol but I have also noticed that the valve cover gaskets are leaking oil so would it be a good thought to do the pcv thing and new o ring while replacing the gaskets?
Did the pcv ;make the gaskets leak? |
#39
Replacing my PCV and it's associated hoses has not prevented my valve covers from leaking or my dipstick from popping up, so no promises there.
#40
I guess the same thing happened as with teh.
My valve has a red handle, doen't yours?
. Earl .... ... .... ><SVX(*> Subaru Ambassador [COLOR=”silver”]1992 Tri Color L[/COLOR] ~45K (06/91) #2430 1992 Dark Teal LS-L ~184K (05/91) #0739 1992 Claret LS-L ~196K (05/91) #0831 1992 Pearl LS-L ~103K (06/91) #1680 1992 Pearl LS-L ~151K (06/91) #2229 1992 Dark Teal LS ~150K (07/91) #3098 (parts car) 1992 White LS-L ~139K (08/92) #6913 1993 25th AE ~98K (02/93) #164 1993 25th AE ~58K (02/93) #176 1993 25th AE ~107K (02/93) #215 1993 25th AE ~162K (02/93) #223 1994 Laguna Blue Pearl LSi ~124K (1/94) #2408 1994 Laguna Blue Pearl LSi ~144K (10/93) #1484 1994 Laguna Blue Pearl LSi ~68K (10/93) #1525 1994 Barcelona Red LSi ~46K (02/94) #2624 1994 Pearl LSi ~41K (12/93) #1961 1995 Bordeaux Pearl LSi ~70K (02/95) #855 1996 Polo Green LSi ~95K (03/96) #872 1997 Bordeaux Pearl LSi ~55K (08/96) #097 2003 Brilliant Red LS1 Convertible ~29K (04/03) #8951 1999 Magnetic Red LS1 Coupe ~33K (04/99) #6420 My Email | Old Locker | New Locker | Picture of 15 of the 19 Last edited by ensteele; 07-31-2011 at 02:50 AM. |
#41
However, although my vacuum lines are relatively pliable, I think I will/should need to replace those soon too.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 07-31-2011 at 11:29 AM. |
#42
I just purchased a box of o-rings and a new pcv valve. I went to 3 stores to find a crows foot but no luck. I guess i need to hit Harbor Freight or order one on the net. Or maybe just bend up a wrench like in that pic. In the mean time maybe the o-ring will prove to be all it needed.
Also, I just pulled out my spare intake and see that it still has a pcv valve, this should give me a chance to practice removal and installation before actually trying it on my SVX.
#43
Remember that the PCV valve is inserted on the underside of the manifold. Acting as if you're "tightening" from the top will actually loosen the valve
In this case its "righty-loosey, lefty-tighty" I always wondered why someone never threaded a nipple into the PCV valve hole in the manifold and ran some tubing to a generic PCV valve, tucking it out of the way under the manifold .
#44
Whenever it comes time to do the PCV on mine, I plan on either doing something like that, or plugging the hole in the manifold and doing a crankcase breather instead.
#45
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
Thread Tools | |
Display Modes | |
