Does anyone have a throttle body they can take some measurement off?
I had measured my intake while it was off the car, but somewhere along the line that piece of paper got lost. I'm going to order the gasket and take the measurements off that, but in the meantime is there anyone who can shoot me a few dimensions? I need:
-diameter of the two throttle bodies (Obviously) -center-center spacing between them -spacing of the 6 bolts The dimensions don't have to be hyper-accurate, just something I can use to get working on a little project.
Re: Does anyone have a throttle body they can take some measurement off?
PM me your e-mail addy?
Disclaimer: The above post is on the internet. |
I.D. of the throttle bodies is roughly 62mm, and the on-center spacing is about 78mm. Not highly accurate but pretty dang close.
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted |
Done.
Wicked, that should be enough to get me started.
