Fiberglass intakes
Just thought I would share what I have been working on here now that I no longer need a MAF... Pics will be put up tonight when I get home from work.. Lets just say that foam pool noodles have now found a new use
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 |
Re: Fiberglass intakes
I've been thinking about this for some time now. I can't wait to see what you come up with. It's got to be better than metal for thermal protection. I believe acetone will eat away pool noodles without harming a fiberglass mold.
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
I always assumed that fiberglass wouldn't make a good intake, seeing as how it is an insulator. But I guess people do make carbon fiber ones?
1992 SVX: JDM STI short geared 6-speed swap, COBB short shifter, slotted cross drilled rotors, Smallcar Clear headlight lenses, 1997 Grill. 1992 RHD WRX: EJ20G, 16G, Cusco Coilovers, Wilwood 4pot/2pot brakes, Defi Genome 60mm gauges, Exotic speed downpipe, 3.5" A'PEXi spec GT catback |
ABS plastic would be ideal, but how can you work with that DIY.
are you running this from an intercooler or just have 2 separate intakes?
Tranny goes in, tranny comes out, tranny goes in.....AW ****, tranny comes out.... |
Just two separate intakes...
How are you going to run this dual setup without 2 MAF's?
Is this an option only for Hydra'd SVX's?
-Craig 94 LSi 5spd Barcelona Red, 14Xk miles. Full custom exhaust (Stebro cat-back, custom rest of the way forward) 8000K HID kit from Tom (SVXfiles), Energy Suspension front sway bar bushings, Non-Droopy visors, Race Concepts C/D + Dimpled Rotors, Axxis Ultimate pads,SS brake lines, Bontrager Works #009 (or something like that), stripped interior. (up next) Full cage, fuel cell, 327 swap |
The joys of a Hydra...
Interesting stuff.
Where can I get me a cool oil cap like that? |
Ebay or Nasioc..
hydra can read from a MAP sensor instead of a MAF, eliminating the need for that pesky MAF. I had a hydra on my old widebody GC8 and ran a MAP instead.
Intake is turning out great... how do u get the pool noodle out after?
I will cut it on each side with a dremel and then smooth out the inside as much as possible before epoxying it back together
awesome... looking forward to seeing it done!
Curious...can you just melt out the 'pool noodle' afterwards? A lot of people making one-off parts use a foam core, form the composite part around it w/epoxy and fiberglass, then melt out the foam core w/acetone or similar solvents. This way you'd have a very strong part with no seams to potentially fail.
