Old 06-01-2009, 10:42 AM
Crysis Crysis is offline
AK Rowdy
Send a message via AIM to Crysis
AWD Binding
Just got my transmission replaced with the 4.44 transmission and now my rear wheels bind when i take sharp turns. I am running a code for the rear speed sensor, but we checked its voltage and it appears to be working. Before the tranny replacement I recently lost my awd and it was just running in fwd; however, the wheels didnt bind when i turned..just didnt have the awd.
Any help?
Old 06-01-2009, 10:50 AM
Re: AWD Binding
Any help?
It sounds like you are having a problem with the transfer clutch assembly or the solenoid. Do you have a blinking power light at startup? Is your cruise control working?
I would recommend approaching the shop that completed your swap, as that shoudl have been addressed prior to returning the car to you.
Old 06-01-2009, 11:23 AM
AK Rowdy
Re: AWD Binding
yes i have the blinking power light at start up...running a code 34? or 32? cant remember exactly...it was rear speed sensor code. They replaced the speed sensor to try and fix the problem and it didnt change anything.
Old 06-01-2009, 11:26 AM
AK Rowdy
Re: AWD Binding
The car is still at the shop...he is trying to figure out what the deal is. The cruise control worked before the swap..ill ask him when i talk to him to see if it works now.
How do I check to see if the transfer clutch is working properly?
Old 06-01-2009, 12:53 PM
paladinwkh paladinwkh is offline
Think, Feel, Drive...SVX
Send a message via AIM to paladinwkh
Re: AWD Binding
Sounds Like the transfer clutch solenoid. If you can get the actual code it would help. You can see if all 4 tires are spinning when it is on the lift. They may not all spin unless some gas is given.
98 Impreza 2.5RS Red 361K "Cherry Bomb"
99 Impreza 2.5RS Black 202K "Midnight" WRXed, SPT CAI, Perrin up pipe, Invida Divorced Down Pipe, cobb tune stage 2.
2013 BRZ on pre order...
---I miss my SVX...
Old 06-02-2009, 05:15 AM
Re: AWD Binding
You did swap out the rear diff too...right?
Old 06-02-2009, 07:25 AM
Re: AWD Binding
Good question Huck.
Old 06-03-2009, 01:08 PM
AK Rowdy
Re: AWD Binding
haha yea the rear differential was swapped. Budfreak did the replacement...he found a ripped wire in the wiring harness of the speed sensor, which was causing the speed sensor code. He did some figure 8s soon after and the binding was gone..all seemed well until it started binding a little bit later on that day. I got the car back yesterday morning and did some figure 8s and it binded for a couple turns; however, it seems to be getting better...havnt had it occur yet since last night so i dont know what the problem is.
Old 06-03-2009, 01:45 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Re: AWD Binding
Mine did that too, eventually cleared up. I think some of it may be due to these junk yard trannys laying around for who knows how long.
Gene
Gene and Ben
