Old 05-30-2009, 11:09 PM
newkid17's Avatar
newkid17 newkid17 is offline
Send a message via AIM to newkid17 Send a message via Yahoo to newkid17
codes...WOW!!! ATF temp sensor?
ok so my car acted up on me today... it kept stalling out, first it started stalling when it was shifting into 2ed than when i would stop, than it stalled when i was crusing about 60 down the road, i think it is because like i said before with my TC not locking out. does anyone know how to do an ATF temp sensor? i know you have to drop the tranny pan and t is on the valve body but where?
and i ran codes today and i got alot of them!!
i got 23,32,31,11,37,33,34... i dont think this can be good...
Old 05-30-2009, 11:17 PM
NiftySVX NiftySVX is offline
Re: codes...WOW!!! ATF temp sensor?
I would check your wiring, that seems like alot of malfunctions to just pop up.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 05-30-2009, 11:58 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
You should probably check the harness at the ECU and make sure its on there.... check your grounds at the battery and engine bay too. Unplug your battery for at least an hour to clear any and all codes, then drive and recheck codes. For that many codes to come up, it seems like a junction electrical issue or bad ECU.
Old 05-31-2009, 08:30 AM
I would say almost definitely some loose wiring looms. Disconnect and reconnect all of them
Old 05-31-2009, 04:05 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Thier probably old stored codes, just reset the ECU and check for codes again.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 05-31-2009, 07:24 PM
newkid17's Avatar
changed my ATF temp sensor today and all while i was doing that i had the battery unhooked, put it back together and now i am only get code 33....
the temp sensor still didnt help with the TC locking out. i dont know what to do or where to start? anyone have any ideas on it?
this thing has been nickle and dimeing me eversince i got it, i mean i expected it being that it is 17 years old but i guess i didnt know what i was getting into and how HARD PARTS ARE TO FIND!!! my parents want me to get rid of it but i love it to death and i dont want to. i have too much blood sweat and tears into it.
im getting a 1989 mazda mx6 next week for $200 so i can let the SVX sit for a while so i can get some money to get her fixed, if i can figure out whats wrong with it...???
Old 06-01-2009, 06:04 AM
dcarrb dcarrb is offline
By "locking out" do you mean locking-up, or engaging properly? Do you some sort of auxiliary ATF cooler installed? The torque converter won't lock properly if the fluid never reaches operating temperature.
dcb
Old 06-01-2009, 04:15 PM
newkid17's Avatar
ok so i found out today it does go into overdrive.....going down the road reving between 3-4K it will like bog and buck all around..i just got done with my rear diff. so it is AWD again finally!!! my speed sensor broke so i bought one from tom and put it in and the speedo. dont work i dont know if this could be part of the problem or not, eventhough it did it(bucking) with the old sensor in too. i put the FWD fuse in it today and it wouldent shift out of first, so this could be something as well???
anyone know where i can start?
Old 06-01-2009, 05:26 PM
The TCU will use the rear speed sensor in place of the main sensor mounted to the front diff in the event of failure of the main unit, but It will not operate the speedometer, and, quite honestly, I have no idea how the transmission would act with that sensor failed. As a first step in diagnosis you need to replace that sensor and start with a system that is free of codes. The torque converter lockup is controlled by a solenoid and that particular solenoid is vulnerable to debris accumulation due to failed components internally. Before I rebuilt my transmission for the first time, my torque converter would violently shudder when it was signaled to unlock at times, the whole car would buck and shake. This is a symptom of the torque converter clutch material coming off, either directly by the clutch being damaged or by filling the transmission with the flaked off clutch material. When I rebuilt mine, I used a torque converter from a later model and cleaned the system thoroughly.
I would first resolve your speed sensor code and then see if your problem still exists. If it does, I would either replace or have your converter rebuilt. Level ten offers this service, among others, that will give a performance boost.
Also, the transmission will not shift out of 1st without a speed sensor if memory serves, and since the speed sensor you have working is the unit that measures the rear output shaft speed, I would hypothesize that it is disabled by inserting the forced FWD fuse.
Old 06-01-2009, 08:26 PM
newkid17's Avatar
ok well it is not the speed sensor bec i took the one out of my girlfriends svx and it still didnt work, tom was saying something about gears being inside the front diff. that might of snapped off?
so what you are saying the TC is bad, am i correct? so i need to just get a new TC?
Old 06-02-2009, 08:31 PM
newkid17's Avatar
bump???? need some help please.
Old 06-03-2009, 12:10 PM
Yes my money is on the converter.
That is a guess made in the dark based on my experience.. but I can't form an accurate diagnosis without driving the car. If there is a problem with the TCC circuit, you've basically got the following components invovled: the lockup clutch, duty solenoid B, and the TCU. If your car is a 92 you need to make sure you have either a new radiator or the radiator trans cooler is bypassed, as the earlier ones have a screen that likes to collect the clutch material from the converter.
Every 92 model that still runs on the original converter needs to have the converter either rebuit or replaced and the radiator either replaced or bypassed. This is the repair Subaru should have performed instead of the filter IMHO
Old 06-03-2009, 01:49 PM
newkid17's Avatar
well it dont do it at low speed its when i reach about 50-65 and than stops at about 80 or so....how do i bypass the trans cooler?
my cruse control does not work either..is this another sign leading to the converter?
Old 06-03-2009, 06:24 PM
Your cruise won't work without the speed sensor. And yea the converter rarely locks below about 55 or so.
Old 06-07-2009, 08:20 PM
newkid17's Avatar
well i took codes again today and im getting alot less than what i was....
23-Air Flow Meter or Circuit (have no idea???)
31-Throttle Position Sensor or Circuit (which might be why im having these problems?)
33-Vehicle Speed Sensor (VSS) or Circuit (because the gears inside the front diff is broke)
34-EGR Solenoid or Circuit (have no idea???)
ALOT BETTER THAN THE 7 I WAS GETTING B4
