Old 05-29-2009, 08:45 PM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
Head bolt nuts
Probably asked a million times, but I finally got a friend to bring a 250 ft lbs impact for my cam gears, that wouldn't break it lose. Called yet ANOTHER friend with 500 lbs one, got it of and pull the cams out, thinking I was about to finally pull one of the heads off but I can't get the head bolts off. Looks to be more than a 12 point bolt, we didn't have a impact socket that would fit but we gently tried to use a normal socket and that wouldn't break it lose. What should I be using to remove these last few bolts?
Old 05-29-2009, 10:06 PM
Re: Head bolt nuts
Head bolt nuts eh??
The bolts have 14mm 12pt heads on them. The block bolts are 12mm 12 heads-/
Old 05-30-2009, 08:48 AM
Re: Head bolt nuts
I haven't pulled them off yet so I'm not sure what they are but I was assuming the actual bolts are in the block and the head drops on to them. Guess I just need a breaker bar.
Old 05-30-2009, 10:41 AM
Re: Head bolt nuts
Yes, you should not be trying to use an impaqct gun to remove those bolts
Old 05-30-2009, 02:49 PM
Re: Head bolt nuts
I wouldn't for putting them back on but I was told taking them off shouldn't be a big deal since the bolts needs to be replaced anyway. Anything else I should know?
Old 05-30-2009, 05:13 PM
Re: Head bolt nuts
You need to loosen them in sequence too.
Old 05-30-2009, 10:54 PM
svxpert svxpert is offline
Re: Head bolt nuts
<<wouldn't for putting them back on but I was told taking them off shouldn't be a big deal since the bolts needs to be replaced anyway. Anything else I should know?>>
normally you can reuse the headbolts, but i imagine your making a mess of them by not using the correct tools. like tom stated, you need to pull them out in order also.
Liberalism is a disease. When you can stare at facts and ignore them anyway, you have it.
Old 05-30-2009, 11:30 PM
NiftySVX NiftySVX is offline
Re: Head bolt nuts
I never use an impact or even an air ratchet on cam cap, bearing cap, or head bolts. I guess I'm afraid that they might seize and tear stuff up. Just my personal policy, I treat them like spark plugs.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 05-31-2009, 09:19 AM
Re: Head bolt nuts
I don't have access to any of those air tools anyway, I just borrowed one because I've been stuck on the came gear for the better part of 2 months now off and on and nothing I've tried would get it off. Thats the only thing it was successfully used on.
Old 05-31-2009, 09:08 PM
Re: Head bolt nuts
<<I just borrowed one because I've been stuck on the came gear for the better part of 2 months now off and on and nothing I've tried would get it off. Thats the only thing it was successfully used on.>>
yeah, thats fine to use it on the cam gears. keep the timing belt on and use it to loosen the bolts that way they (pulleys) keep from rotating. just dont use it to put them on.
Old 06-01-2009, 06:30 AM
Re: Head bolt nuts
Unfortunately I bought my car with a broken timing belt, that would have helped a lot though.
