Old 05-15-2009, 04:20 PM
patb3 patb3 is offline
wheels
hey guys,
i have a 94 svx lsi, and when i went to get a new set of tires put on, they showed me that one of the original wheels was cracked, and that the other 3 were dinged and dented pretty good too. So, i've been lookin on the net for a replacement set of 4 wheels/tires and am having a difficult time. im in maine so i don't want to go bigger than the 16" (crazy potholes and frostheaves up here... in fact that's why i had to get a new set of tires in the first place, damn goose eggs). anyways, i've digressed from what i was getting at. i am under the impression (from a friend that also has a svx) that the following specs are what i need to look for:
lug spacing 5x114.3
offset 42+mm
the only thing i've been able to find so far is a direct factory replacement, and they're 170 bucks a piece (just for the wheel). was hoping someone on here has run into a similar issue before and could kindly point me in the right direction, or shed some light on this (this is the first car i've had where rims are going to be replaced)
thanks a bunch! :-)
Old 05-15-2009, 04:37 PM
Re: wheels
Here's 49 to start with:
http://www.discounttiredirect.com/di...rw=&vid=006494
'92-'97 are the same.
Old 05-15-2009, 04:43 PM
Re: wheels
yah i've been there already there unfrotunately, and none match the specs i listed (assuming i listed them correctly) except for the ones that are currently out of stock.
Old 05-15-2009, 04:56 PM
Re: wheels
They don't have to be exactly +42. A couple of numbers up and they are still compatable.
Old 05-15-2009, 05:13 PM
Re: wheels
ohhhh
well that makes things a lot easier... when it says 114, is that shorthand for 114.3, or is it actually 114? Thanks a bunch blacky :-)
Old 05-15-2009, 05:14 PM
Re: wheels
Stock is +55. Almost nothing is +55, so anything between 42 and 55 will do you fine. The widest 16" wheel you will typically find is 7.5", which should be readily available in a +48 offset.
Old 05-15-2009, 05:25 PM
Re: wheels
Originally Posted by patb3 View Post
ohhhh
Yes, 114.3 is commonly listed at 114.
Old 05-15-2009, 05:38 PM
Re: wheels
thanks 1986,
i have selected the one here
http://www.discounttiredirect.com/di...w=7&vid=006494
please tell me if this would be acceptable. i love you guys, your the best!!!
Old 05-15-2009, 06:57 PM
Re: wheels
Nice looking wheel and only $390.00 for the set. I wonder about the center cap?
This is the one I like:http://www.discounttiredirect.com/di...w=7&vid=006494
Old 05-16-2009, 01:32 PM
Re: wheels
Ya that was my first pick too actually but its out of stock
Old 05-16-2009, 02:20 PM
Re: wheels
They are special order. It only takes a few days extra. Give them a call.
Old 05-16-2009, 03:40 PM
Jeremy'sSVX's Avatar
Jeremy'sSVX Jeremy'sSVX is offline
Send a message via AIM to Jeremy'sSVX
Re: wheels
http://www.subaru-svx.net/forum/showthread.php?t=50104
If your interested i can professionally mount and balance a new set of tires. I have access to any brand/size of tires you would like.
-Jeremy-
1994 Barcelona Red LS 97,xxx miles
- JVC Indash head unit, polk 6.5's, 6X9's, 2" tweeters, and 8" JL audio subwoofer run off of MA Audio M589I amp. Fiberglass Front splitters molded in, Shifted back stock spoiler, & repainted minor faded parts (Mirrors, rear quarter garnishes),18" murano 5-spoke wheels w/cooper zeon 2xs tires, '97 grille
