Old 07-22-2002, 06:14 PM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
Valve body swap?
How hard is it to swap a valve body from one tranny to another? It is not necessary to remove the tranny, is it? Is this something a home mechanic can do? I have replaced clutches in manuals, but have never touched an AT. I want to pull my Level 10 valve body off my wreck and put it on my new purchase. Thanks.
Stephen
92 Ebony - Level 10/n2o REAR-ENDED
92 Teal - painted yellow/4.11 5spd/n2o SOLD
92 Claret - 4.44 SOLD
94 Barcelona - FWD SOLD
92 Ebony - 3.90 SOLD
94 Laguna ROLLING w/4.44s/Ecutune ECU +TCU/STI springs/Infiniti M45 rims
Old 07-23-2002, 06:38 AM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
Yes you can do it
It can be done w/o removing the tranny. If you have the shop manuals, the procedure is there. Otherwise, call Pat at level 10 and I'm sure he will give you some pointers.
'20 Honda Ridgeline
http://www.x35design.com
Old 07-23-2002, 11:17 AM
elninoalex's Avatar
Registered Abuser
Thanks dude.
Old 07-25-2002, 07:45 AM
svx_commuter's Avatar
I talked to a guy in Canada that did this. The hard part is keeping the accumulators in place when the valve body is out.
Old 08-20-2002, 11:43 AM
cbx-man cbx-man is offline
I removed & replaced mine myself using the factory manuals. I would be willing to fax you the pages needed if you are interested. What I did to keep everything correct was to draw the valve body layout onto corrugated and then put the corresponding bolts into the proper place on the "map". There are 2 different lengths of bolts. The 3 solenoid shift springs will fall out but if you use a dab of vaseline it will allow the springs to stick to the flat surface until you slide them into their pockets. No worry of getting them in the wrong place- all 3 different. Unplug the electronic thingie and be careful not to pinch it when re-installing. Torque the bolts to about 6 ft/lbs - use a 1/4 " drive torque wrench and convert to inch/lbs and do in 2 steps (like torqing a head)
Old 05-04-2006, 05:03 AM
Kaline
Manual on Dropping the valve body
Would anyone be willing to scan the factory service manual pages that cover a valve body drop? I need to do one on my '92 SVX AWD to do some repairs on the trans. I would appreciate the help, as I don't have a factory service manual.
Old 05-04-2006, 05:56 AM
SVX-FF's Avatar
SVX-FF SVX-FF is offline
Live it, Love it, Breathe it
Stephen,
If your wreck has a Level 10 valve body is the tranny a Level 10 too?
If it is you would be much better off wrapping the whole tranny and not just the valve body.
Steve
03 Ford Expedition(hers)
Are you in?
My Old Locker
A 4.11 Founding Father
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
Old 05-04-2006, 07:21 AM
Kaline
AWD Auto Trans Valve Body
I do not have a spare transmission and I need to re-install the parking pawl mechanism (long story with broken parts is how the mechanism came out). It appears the only way to re-install it is to drop the valve body. My problem is similiar to the original post (which is why I did not start a new post)
UPDATE: CBX-MAN scanned the pages from the factory service manual for me and I was able to drop the valve body. You definately need the diagram to know which bolts you need to remove and what the installation torque is (very low). I can share these pages if anyone needs them!
