Old 02-04-2009, 05:43 AM
dcarrb dcarrb is offline
Re: Oil dipstick mystery
Originally Posted by Mensaf View Post
This a regular Autozone part?
You should be able to get a PCV valve, and probably a suitable O-ring, at any auto parts store.
dcb
Old 02-04-2009, 03:02 PM
Even with a bad O ring the dipstick should not pop without internal pressure.
As per Harvey's #8 post. Treat the cause, not the symptom.
Do the PCV valve. Clean the gunked up passages. Replace the O ring.
No more problems.
Thanks Joe, I was expecting a post suggesting, 'to fit a spring to the dipstick, so that when the pressure blows it up, the spring will pull it back down, problem solved.'
Old 02-04-2009, 06:00 PM
SomethingElse's Avatar
word words wording
Mystery fun...
I just stuck some JB weld on the top of my dipstick tube, burch wont pop anymo....just make sure you clean all of the oil off of the tube so It will adhere better to the metal and form a solid bond.
Eric
Old 02-04-2009, 06:20 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Originally Posted by SomethingElse View Post
Mystery fun...
!!!! Hope none fell in, or will in the future!
Old 02-04-2009, 06:23 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Mine pops up too.. It's no big deal. OT just pops it in when he sees it, lol.
Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1˝" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint.
Old 02-04-2009, 06:38 PM
Or, Or............
Drill a small hole through the top of the dipstick. That way it will whistle when the PCV needs attention.
Old 02-04-2009, 07:01 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Or, Or............
Oh geeze, why stop there Why not make a ram-air system for it through the hood so the PCV valve doesnt have to suck so hard?
Old 02-04-2009, 07:52 PM
kwren's Avatar
kwren kwren is offline
A cheap fix!
I just cut 6 inches of the length of mine and haven't had any trouble since! Been about 2 months...
Keith
Old 02-04-2009, 08:34 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Originally Posted by kwren View Post
A cheap fix!
Keith
OUCH!!!!!!
Old 02-05-2009, 12:01 AM
I have seen some of them move up 3 or 4 inches. This is by vibration and not pressure. Either way, the O-ring should be replaces.
