Old 01-13-2009, 12:39 AM
SuberNatural SuberNatural is offline
Exclamation No engine braking in 3rd gear
1st gear and 2nd gear both stay right with the engine.
D4 idles down after a few seconds of coasting as it should.
D3 goes right from pulling in gear to idle (as if in neutral) then after a second or two hits 3rd gear and then neutral until the car slows.
I have no codes on the TCU.
The trans resistor is plugeed in and good.
Any help would be appreciated. I just had the trans serviced etc.
1992 Liquid Silver/Black LSL
LeveL10 Stage 3 Trans and associated stuff
Old 01-13-2009, 01:04 AM
log1call log1call is offline
Re: No engine braking in 3rd gear
So are you saying that the engine braking in third gear is intermittent? Also, is this in third while the shift lever is in drive or is this when you have pulled the lever to third to try and slow faster?
Old 01-13-2009, 01:10 AM
This is with the gear selector in D3.
It is not intermittent, its mostly non-existent except for every once in a while or sometimes when driving slow. I have not found a pattern yet.
Old 01-13-2009, 02:06 AM
Well to start with you should go through the standard tests... stall test, line pressure tests, speed shift tests up and down, time lag test, check "crispness" of changes etc. There is a clutch and a one way sprag clutch in there that can both give engine braking problems, not to mention several valves.
It might be a good idea to see an auto trans place and get them to do a diagnosis for you.
Old 01-13-2009, 03:26 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
IIRC, engine braking is something to do with shift solenoid 3.
Have you checked the fluid level since the service?
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 01-13-2009, 11:06 AM
^^^ is there a how-to for that?
I always check where I park and have no signs of leakage but i will check here in a few minutes.
Old 01-13-2009, 01:38 PM
(level10 trans btw)
stall test - 3000 RPM
line pressure tests - NA
speed shift tests up and down - Very Responsive
time lag test - < 1 second
check "crispness" of change - Very Crisp (but no slamming)
This morning I went for a drive, and only marginally warmed the motor. When it was cold there was no lockup as expected. However after about 3 miles or so D4 was available. So i put it in D4 and drover probably 8 miles (round trip) checking every once in a while to see if 3rd gear was behaving normally. And today it was. So im starting to think that maybe this is a temperature issue? I've never seen the ATF temp light while driving and don't drive the car very hard.
Let me know what you guys think.
Old 01-13-2009, 03:40 PM
michael's Avatar
michael michael is offline
What Potholes ???
have you checked the resistance of the resistor by the battery.
Wanted: Steering Wheel
Old 01-13-2009, 04:18 PM
Yes, it's testing good between 12.1 and 11.9 ohms
Old 01-13-2009, 04:58 PM
michael's Avatar
What Potholes ???
do you have any shift kits installed?
Old 01-13-2009, 10:39 PM
Nope, just whatever level10 did. I should know more specifically what was done to the trans tomorrow.
Old 01-14-2009, 12:33 AM
There are a heap of variations in trans and I'm not sure which you have but, it's quite common to not have engine braking in some situations in some models/versions and specificaly in third gear... that is to say that there are models that will have engine braking in d4 but none in third in some circumstances.
I suggested you do the standard checks because, if they all look good then my advice would be not to worry. Keep an eye and an ear on it for a while and monitor the circumstances and read a workshop service manual which will describe the operation.
You could look here for a manual.. http://www.main.experiencetherave.co...ans/FSM_Scans/
Those figures you have look ok. It would have been nice to see a line pressure check but if the lag is good it is PROBABLY ok. There is a oneway clutch inside which is like a ratchet and not actually a clutch at all... I thought that could be crook but they generally reckon that will show up as a lag until it grips. It could still be slipping if it gets turned gently and grab on if it gets a jolt... but that's about the only thing I can think of that mght give intermittent/undesigned for braking fault.
Keep an eye on it's behaviour and read the manual.
Old 01-14-2009, 02:24 AM
stiguy's Avatar
stiguy stiguy is offline
i noticed my cars does the same thing but mine does it all the time hot or cold.
Old 01-14-2009, 04:49 PM
oab_au oab_au is online now
To tell what the trouble is, you have to see if there is engine braking in 2nd gear. If there is no engine braking in 2nd, and no code for solenoid 3, it is a mechanical failure in the box. If it does brake in 2nd, then it can be a few other things.
The over-run clutch is controlled primarily by the Shift solenoid 3. in 1.2.3, gears. 3rd is treated differently to the rest, as the clutch cannot be engaged when the box is driving, or it will lock-up.
In third the solenoid is on but the engagement is controlled by a shuttle valve that uses the drop in line pressure, to tell if the throttle is closed, to apply the over-run clutch.
The symptoms that you say, "then after a second or two hits 3rd gear and then neutral until the car slows. ", seems to be the way it shows up, and can be caused by;
1.Throttle position sensor.
2. Dropping resistor, too high in resistance.
3. If the line pressure regulation spring has been increased to raise the line pressure. ( Level 10 may have done this)
Old 01-14-2009, 04:56 PM
I do have engine braking in 1st and 2nd gear.
The resistor tests in at 12.1-11.9 ohms
I guess I will check the TPS voltage and then look at getting a line pressure test. I don;t think there are any serious problems with the box its just an annoyance that i hope doesn't create a problem.
Thanks for your input. I just wanted to add that yesterday when it was super cold out I had engine braking in 3rd gear for the entirety of about an 8 mile run. But yesterday when it was just as cold and I went for a longer drive I didn'y have 3rd gear breaking.
