Old 01-06-2009, 10:39 AM
evilsvx's Avatar
evilsvx evilsvx is offline
need u joints for driveshaft
as titled, i need the u joints for a 92 ls-l driveshaft. my cousin told me they dont sell them on the subaru dealser and the only place is aftermarket where i can get them. thanks
Old 01-06-2009, 11:17 AM
ShiuludeSVX's Avatar
Re: need u joints for driveshaft
I just took a chance at buying a set from ebay...Th guy says that they can be replaced, but the originals are "staked" in. We will see what happens.
Are your's singing like mine have started to do? Otherwise, a Drive Shaft shop, or buy a new full assembly of the shaft.
My local dealer says he can get the whole assembly, but it's over $500
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 01-06-2009, 11:58 AM
evilsvx's Avatar
like you hear it after like ten minutes driving, is like a shaking thing. yeah. my cousin will check it. he said they can be taken out. i hope they are. im not spending 500 bucks for that. i rather save up a lot and swap it to stick. right now i just want it to drive properlly
Old 01-06-2009, 01:03 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
If the 94 Lsi are the same, I have them. Make offer.
1995 POLO LSI 76K MILES SOLD
Old 01-07-2009, 08:21 AM
Can anyone clarify whether or not these can be replaced, with a little talent????? I know the issue would be RPM balance, so I'm not forgetting that part.
The Worm
_______________
No Mods, 33K Miles
Old 01-07-2009, 03:54 PM
SomethingElse's Avatar
word words wording
U CAN GET THEM from advance auto. they are approx 30 bux a piece. I would not recommend doing them without a shop press. It will take you hours to get that thing out unless u cut with something. have a great day
Eric
Old 01-07-2009, 05:09 PM
evilsvx's Avatar
im not sure, im new in the subaru world actually.
cool, do u know how many of them i will need for the svx?
Old 01-07-2009, 06:46 PM
From the schematic I believe there are 3 in total. 2 on the front shaft and 1 on the rear.
Old 01-07-2009, 07:35 PM
Hondasucks's Avatar
Subaru Technician
They are staked in, you can replace them but usually only once maybe twice, then you run out of metal to stake, and you replace the shaft. Try and find one in a junkyard, chances are it'll be good, that's what I did when my front U-Joint took a dump in my SVX.
1986 VW Jetta
Old 01-08-2009, 02:56 PM
evilsvx's Avatar
right now im just going to change the u joints. im saving for my 6sp swap right now
Old 01-11-2009, 08:46 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
I had a shop rebuild mine. They cut and replaced the yokes so that a universal U-joint with a grease fitting could be installed. A balance was also needed after this type of work. It ran about $300 total.
Old 02-28-2009, 02:16 PM
Only 2. One at the Spindle end, and one on the Differential end..
The Bearing in the middle does not use a joint on either side of it.
The Worm
_______________
No Mods, 33K Miles
