Old 01-04-2009, 06:20 PM
andreoz andreoz is offline
Send a message via Skype™ to andreoz
Exclamation Sensor lights on dash come on when off idle
After a recent service, my various sensor alarm lights come on as soon as the car is not idling - battery light, stop lamp light, Park Brake, Brake Fluid and Antilock Brake.
Has anyone had the pleasure of a similar experience? If so what is the most likely cause before I take it back to the workshop and give them a roasting...
Old 01-04-2009, 09:11 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Sensor lights on dash come on when off idle
Clarify: Not idling
Does that mean as soon as you rev the engine??
Or does that mean as soon as the car is turned off?
Old 01-04-2009, 11:43 PM
kwren's Avatar
kwren kwren is offline
I would just take it back and give them a good roasting for general principles! They probably sabotaged it anyway...
Keith
Old 01-05-2009, 05:41 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
My guess is that your alternator belt is slipping. Check it is tight and in good condition.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 01-05-2009, 06:46 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Yeah, mine gets angry and lights up all over like that when my PS belt breaks or comes off... Which is often..
Old 01-05-2009, 09:59 PM
When idling they turn off and when rev up they come on. Alternator belt is fine and tight.
Old 01-05-2009, 10:12 PM
Green1995SVX's Avatar
I would bet it is a problem with the voltage regulator (internal to the alternator). I think you need a new alternator.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 01-06-2009, 10:32 AM
b3lha's Avatar
Phil & Belha
Search the forum for "Christmas Tree Lights".
You may come across a detailed post from Trevor explaining why the problem occurs.
Old 01-06-2009, 12:39 PM
kwren's Avatar
yup... chances are..........
Old 01-06-2009, 09:47 PM
edmsvx's Avatar
edmsvx edmsvx is offline
Check your wiring to your battery. I have seen this in my svx, and found the battery post connections very corroded. ( okay at idle, lights would come on very dim at about 3500-4000 rpm )
1992 (JDM) CXD Ebony Pearl 90K km written off hail damage
1996 (CDN) Lsi, Polo Green, 296,000 km
2009 Legacy Spec B
Old 01-07-2009, 08:43 AM
SVX JAZZ's Avatar
SVX JAZZ SVX JAZZ is offline
Tired
Mine turn on and off at idle. Also the engine RPMs rise slightly. My belt was bad so I thought it was slipping. I replaced it and had the same problem. Its been doing this for a while and only does it after a long drive. I am going to test the alternator today hopefully.
Old 01-15-2009, 06:56 PM
Smile Re: Sensor lights on dash come on when off idle
Thank you to all! Great lot of info and it was definitely the alternator - putting out 18V!! As they are no longer manufactured my electrician managed to get another Subaru model where he simply had to modify the bracket slightly and use the pulley from the original alternator. All is well now and the "Christmas Lights" are gone. Very coincidental that they did come on at Christmas time!!!
Old 02-08-2009, 03:30 PM
Thanks to all and the Christmas lights thread - it was the alternator. Had it replaced with a new Subaru (not SVX but fits OK using original pulley). All lights OK. Within a week my dash lisghts started pulsating pointing to an alternator problem. It was - had it replaced for another new one under warranty - let's see it this lasts a bit longer!!
Thanks again for the assistance!
Old 02-08-2009, 06:04 PM
An alternator from another subaru won't do the job. The SVX's alternator is a higher output unit than other subarus. You can get a Subaru Remanufactured alternator at any Subaru dealer. If it's a larger dealer they probably even keep it in stock.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 02-08-2009, 08:48 PM
Thank you for that message. We are talking "Down Under" where there were very few SVX's imported so it is becoming somewhat of a rarity with virtually no parts available! I'll get the full specs of the replacement!
