Old 12-27-2008, 03:55 PM
sicksubie's Avatar
Alternator question
Ever since I finished the 4.44 swap on my pearlie, all my dash lights have been on as if my alternator was going bad. Well I have driven about 50-60 miles since the swap with these lights on and there has been no hesitation or anything that would indicate low voltage. The headlights work great (high beams too), radio, etc, etc all work as they should. The battery is brand new as of 2 months ago, but it drained during the time I was doing the swap. Is there a chance that the lights are just on due to an undercharged battery that will simply take more driving to make the lights go away?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 12-27-2008, 03:57 PM
kwren's Avatar
kwren kwren is offline
Re: Alternator question
nope.............
Old 12-27-2008, 03:59 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
what lights are on? and whats your voltage from the battery from idle?
- John
Old 12-27-2008, 04:00 PM
kwren's Avatar
I would put a digital tester on it and see exactly how much voltage the alternator is putting out. I would check it with different things turned on while the engine is running
Old 12-27-2008, 04:04 PM
kwren's Avatar
Sad when you live in a town where you see a police officer and cringe.
We all do that!
Old 12-27-2008, 05:22 PM
sicksubie's Avatar
put one lead on the positive terminal of the alternator and the other ???
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 12-27-2008, 05:30 PM
on the negative terminal.
Old 12-27-2008, 06:07 PM
sicksubie's Avatar
which is???
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 12-27-2008, 06:15 PM
any ground.
Old 12-27-2008, 06:29 PM
sicksubie's Avatar
That is what I thought, but the whole negative 'terminal' comment threw me...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 12-27-2008, 06:46 PM
kwren's Avatar
red on positive battrey cable and black on negative
Old 12-27-2008, 06:48 PM
kwren's Avatar
Terminal sounds so final but in this case it isn't!!
Old 12-27-2008, 08:00 PM
sicksubie's Avatar
12.75 volts at idle with the headlights on...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 12-30-2008, 04:15 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
You need an alternator more than likely. Should be at least 13.2 at idle. Could be bad grounds or connectors but more than likely its time for a rebuild. Should be able to have it done for $120 out the door in your area.
Old 12-30-2008, 04:17 PM
yep...
