to drain the oil out of the rear-end...
does it take a special wrench?
It looks like a square thingie??? 85 wt oil is right?? Is synthetic the best? Thanks, Keith |
Re: to drain the oil out of the rear-end...
Keith,
That square socket fits a 1/2" ratchet IIRC. Make sure you can get the top/ filler plug out first before removing the bottom/drain plug though, for obvious reasons. I would follow the owner's manual recommendation as far as lubricant. Glenn
"The only thing necessary for the triumph of evil is for good men to do nothing" Aaron Burke 1993 25th Anniversary Edition #63 of 301. R.I.P. Rojo 7/24/2008 She saved my life! 1997 Ebony Mica Pearl LSI. BLACKBERRY 1998 5-Spd Legacy GT Wagon in Glacier White: NUBURU 2005 Cadillac STS in Sandstorm Metallic: STORMY Veteran and farthest traveler of 1st SoCal2MuseumsMeet2010. http://www.subaru-svx.net/photos/user.php?RojoRocket |
There is a special socket that's a little bit bigger than a 1/2" drive square. But usually if it's not too siezed, any 1/2" ratchet or breaker bar will work, just watch that you don't twist the drive in there.
75-W90 API GL-5 gear oil, capacity is ~2 pints. Full is when the fluid level is even with the bottom of the upper hole. (Make sure the car is sitting level)
1992 SVX LS-L #1222 Pearl White 1987 GL Turbo wagon, 5 lug conversion, D/R 5 speed (Rice killer) 1992 Dodge Ram 4x4 diesel (car hauler) 1968 Dodge Polara convertible (Camaro killer) 1990 Toyota Corolla FWD auto (330,000 mile grocery getter) 1986 VW Jetta |
Thanks everyone!
Will tackle it tomorrow after the Texas Tech Red Raiders beats the Texas A&M folks! Too late for me tonight. I appreciate all the help. Keith |
Hijack thread
So, how often does the gasket go bad on the rear diff? Its part number 28361 on this diagram. http://www.subaruparts.com/diag/?mod...category=195-1 My diff is dripping oil. Its always got a drip of fresh oil on it, and the whole thing is just caked. Im trying to pinpoint what exactly is leaking, so I can get it fixed before something happens. I checked the oil in it, and its a little below the top hole. So how much work would be involved if I was to replace that main seal on it? Would I have to drop everything off the car? Or can I take it off and replace it while its on the car? Thanks! -Dennis /Hijack
D.J. McPhee 2006 Infra-Red Ford Focus ZX3 ~ 67k No longer SVX'n, Ill always miss them! 1995 Polo Green LS-i ~ 95k 1992 Dark Teal LS-L ~ 145k (04/91) #2231 1992 Claret LS-L ~196K (05/91) #0831 Last edited by mysvxrocks; 10-18-2008 at 12:53 PM. |
what gasket? the link just gets to subaruparts.com... sign in and then where?
Oh oops didnt realize that. Its the main gasket for the rear diff. Heres the diagram.
Again its part number 28361. Here is a picture of mine. Edit: Nevermind, I can see clearly that you would have to drop the diff out to take the rear cover off.... Just wouldnt be that easy. So, judging by the pic, do you think thats whats leaking? Then if so, just how hard would it be to replace it?
D.J. McPhee 2006 Infra-Red Ford Focus ZX3 ~ 67k No longer SVX'n, Ill always miss them! 1995 Polo Green LS-i ~ 95k 1992 Dark Teal LS-L ~ 145k (04/91) #2231 1992 Claret LS-L ~196K (05/91) #0831 Last edited by mysvxrocks; 10-18-2008 at 07:08 PM. |
Bump for the pic
D.J. McPhee 2006 Infra-Red Ford Focus ZX3 ~ 67k No longer SVX'n, Ill always miss them! 1995 Polo Green LS-i ~ 95k 1992 Dark Teal LS-L ~ 145k (04/91) #2231 1992 Claret LS-L ~196K (05/91) #0831 |
Spray it all off with some brake cleaner and wait a few days and see if you can see where it is coming from. Could be the gasket, but could also just be the plugs, they will leak some if they aren't tight.
To get the rear cover off, undo the big bolt at the top that goes through the hanger, and the two nuts at the crossmember, unbolt the rear flange of the drive shaft and lower it down, and put a jack under the diff and push it forward until the studs clear the crossmember, and then let it drop down until you can get the cover off. You might not even have to get a gasket, just scrape all the old gunk off and use some black silicone. (Or three bond if you can get a small tube of it, that stuff works great)
It could also be the axle seals (where the axles plug into the diff) but that looks more like the gasket to me.
So, how hard would you say the job is? And about how long to do the job? Anything else I should get if I am to do this? Can I get new busings somewhere?
D.J. McPhee 2006 Infra-Red Ford Focus ZX3 ~ 67k No longer SVX'n, Ill always miss them! 1995 Polo Green LS-i ~ 95k 1992 Dark Teal LS-L ~ 145k (04/91) #2231 1992 Claret LS-L ~196K (05/91) #0831 Last edited by mysvxrocks; 10-20-2008 at 08:02 PM. |
Here is the section from the service manual on the rear diff.
Holy crap that looks like a LOT of work
I was thinking the same thing and I've done it a bunch of times...
