Old 05-16-2008, 07:18 PM
poweredx2 poweredx2 is offline
Intake manifold spacer installed
As I posted a few weeks ago about installing another set of lower intake manifolds with the stock setup,several issues became clear such as hood clear,egr setup, an so forth.I just cut the top portion of both lower intake manifolds and machined them at work to about 1/2 inch thick drilled out the threaded holes and made some gaskets.The install was easy except for the egr which I managed to get the bottom bolt in and tight and and while tightening the top, THE HEAD BROKE OFF THE BOLT.Well I used some liquid steel to seal the egr for now,ok now for the drive.The car feel more responsive than before,pedal taps still get wheelspin,I will head to the track tomorrow to get some times.The cars averages 2.1-2.2 60ft and high 9.5-9.6s in the 1/8 mile.I will post any improvements,but I don't think my times will improve being fwd.
Old 05-16-2008, 08:07 PM
Can anyone direct me to a company that makes a throttle body spacer for the E33.
Old 05-16-2008, 09:56 PM
redlightningsvx's Avatar
Collision Refinishing Tech
I thought outlaw engineers makes a 5 pice spacer kit with a throttle body spacer in it?
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 05-16-2008, 10:26 PM
Affirmative.
Old 05-17-2008, 11:41 AM
Sir. Nate's Avatar
Sir. Nate Sir. Nate is offline
SVXtreme
TB spacer would be awesome.
-Nate
'92 LS-L Pearlie
Old 05-17-2008, 09:23 PM
JLHollowX13's Avatar
JLHollowX13 JLHollowX13 is offline
Send a message via AIM to JLHollowX13
would anyone care to explain to me what a tb spacer and an intake spacer does exactly? i know if affects performance (obviously), but im not sure how each one does it exactly. are they hard to install also? thanks!
1992 silver/black LSL - 142,xxx miles
power mode switch, ecu crush, intake silencer removal, ecutune, B&M transmission cooler
1971 toyota landcruiser - project.... someday
Old 05-18-2008, 07:46 AM
It keeps the motor cooler.
Seth
Past subies:
Other toys:
Old 05-18-2008, 08:48 AM
Track was cancel yesterday do to servere lightning in the area.Driving home with temps around 60 degrees outside midrange power feels much better.I am ordering a throttlebody spacer from outlaw.
Old 05-18-2008, 11:38 AM
It keeps the intake charge cooler and increases plenum volume slightly.
By virtue of retaining heat from the intake, it would stand to reason the motor is hotter, if negligibly.
