Old 03-16-2008, 06:23 PM
Dessertrunner's Avatar
Solid copper head gaskets
Does anyone have any ideas if copper head gaskets work or not, are then better then the orignal?
Tony
Old 03-16-2008, 06:24 PM
Most people that use copper gaskets do so because you can re-use them, and they will generally handle more boost than stock gaskets...
Old 03-16-2008, 06:47 PM
Have any of the guys boosting used them?
Old 03-19-2008, 04:05 PM
cdigerlando cdigerlando is offline
Not that I know of, but I was considering getting some made for our car at one time. I'm going with cometic head gaskets now. They are off the shelf. At one time I was considering reducing the compression with copper head gaskets, but decided against it. It would be interesting to see if it would work though.
Chuck D.
1992 Subaru SVX LS-L - Heavily modded turbo
2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods
Old 03-20-2008, 12:32 AM
The disadvantage of coppers is that (as I have read in the past) gets "eaten" by water... any comments on that?
Old 03-20-2008, 05:20 AM
Copper roofs are the longest lasting roofs.....and they are exposed to water....
I just hadn't heard that before, but I've never used a copper gasket before...but know some drag racers that do....
Old 03-20-2008, 08:51 AM
GreenMarine's Avatar
From POST-***** to LURKER
It's possible that hot water (antifreeze) would have an effect on the copper. Water becomes "corrosive" in a sense, when it is boiling... Somehow though I doubt that copper would be effected by hot water. I mean copper roofs and the hulls of ships are just some of the uses of copper and they both last a VERY long time... I'll look into it though and see if there is any reaction between antifreeze and copper at high temps...
~ Chris
Old 03-20-2008, 01:27 PM
RallyBob's Avatar
RallyBob RallyBob is offline
Registered fabricator
There is already a company that makes copper head gaskets for the EG33. I can't remember the name, but I can look it up.
FWIW, the true down side to copper gaskets is they tend to 'weep', or seep coolant until the engine is up to temp. Even fully annealed, they are not truly compressible. I ran a copper head gasket on my Toyota 22R w/supercharger 20+ years ago, and it was aggravating to say the least. There was always coolant leaking, and that was with ARP head studs and with an o-ringed block. Hylomar is supposedly the best thing to use to prevent or reduce the seepage, but I never tried it back then.
Bob Légère
EG33 Impreza tweaks
Old 03-20-2008, 01:35 PM
There are some real interesting issues coming out it would be good to find some one using them now.
Tony
Old 03-20-2008, 03:14 PM
Tony
On an SVX, doubtful... On WRX's oh yeah... You can probably check on NASIOC in the Engine sections for more info
~ Chris
Old 03-20-2008, 05:16 PM
Nomad Nomad is offline
The car named NIGHTMARE
Send a message via MSN to Nomad
I've bought them and waiting to install them this summer on my second engine ... tell you latter !!
Nightmare is the name of the car...
Old 03-20-2008, 05:33 PM
Were did you buy them and how much?
Old 03-21-2008, 08:38 AM
took from :
http://svx-motorsport-accessories.st...net/index.html
I think it was something like 355 $ with shipping .
Old 03-21-2008, 08:47 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
To follow up on what Chris was saying...Copper gasket + aluminum block = dissimilar metals which can contribute to galvanic corrosion. Honestly, I think that LAN's approach to machining in a slight "step" around each cylinder provides enough additional "crush", making stock head gaskets adequate. A related point is that we're starting to see more HG leakage across the EG33 community now that we're getting more engines in the +190k mile region (mine included), so I believe we can take it as a given that the stock HGs are good for at least 150k miles (okay, now folks can chime in on how their HGs blew in less than 150k miles)
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 03-21-2008, 02:55 PM
Bill,
I agree with your point on the length of time the current head gaskets last as the one on my car is failing now and the car has 440,000 K on it. The eonly time you get trouble earlier is if you cook the engine for some reason.
Tony
