Old 09-29-2007, 07:03 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Question 4.44 in fwd svx
stupid question can this be done or do you need to convert to awd for it to work?
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 09-29-2007, 07:07 PM
JaySVX's Avatar
JaySVX JaySVX is offline
I wouldn't reccomend "converting" to awd, it's quite the hassle i hear. However, all you have to do is not connect a driveshaft, and bam, fwd 4.44. I'm sure there's a bit more to it, but that should work.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 09-29-2007, 07:11 PM
thanks for the input see i think my tranny might be slipping and id rather go to 4.44 but i dont know how to do it because i don't think anyone has done it yet
Seth
Past subies:
Other toys:
Old 09-29-2007, 07:16 PM
JaySVX's Avatar
Give it to tom, he'll make something out of it. Worst case scenario, install a rebuilt trans and a cooler, and you should see significantly improved life.
Old 09-29-2007, 07:21 PM
jeffast jeffast is offline
I kill more trannies then god
you probely could but i wouldn't, as i don't think the diff could take it. on the same note with 4.11 's i could roast the tires in front wheel drive with no problem, so i think traction would become a major issue with 4.44's. it's not that bad to convert to 4wd, if its like most older subie's you just need the rear lower suspension, and then you have to mount the center of the drive shaft. i havent gone from fwd to awd, this is just what you have to do in an 80's era to go i'm sure someone more informed will chime in.
1991 xt6 eg33?
1993 gc track car
Old 09-29-2007, 07:32 PM
i was goin to try the 4.44 trans with matching rear. so it would still have traction problems from quicker power because i was quoted about $2400 for tow, labor, parts for the awd conversion with 4.44s
Seth
Past subies:
Other toys:
Old 09-29-2007, 07:34 PM
uh you lost me
1991 xt6 eg33?
1993 gc track car
Old 09-29-2007, 07:36 PM
srry i meant would it be possible to have the 4.44 with the fwd without ill side affects or just get converted to awd with 4.44s
Seth
Past subies:
Other toys:
Old 09-29-2007, 07:59 PM
yes you can convert a 4.44 awd trans to a fwd... Need to get in behind the rear plate to swap some parts but it is easily done
Old 09-29-2007, 08:02 PM
2 questions:this wouldnt hurt the traction from more power to the wheels?
what parts would need to be changed?
Seth
Past subies:
Other toys:
Old 09-29-2007, 08:06 PM
the rear cover... The output shaft... thats about it I think... off the top of my head tho
Old 09-30-2007, 09:20 PM
NiftySVX NiftySVX is offline
I converted mine from FWD to AWD and it wasn't bad, except that I had to custom make some of the wiring, like the FWD fuse and the wire for the FWD and (useless) AT-Oil temp light. I was always going to set it to a trigger on my digital trans temp gauge but when i got it I found out the new models no longer had the output for it.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 10-12-2007, 08:52 PM
rallyingrob's Avatar
rallyingrob rallyingrob is offline
when i first got my 4.44 awd running, it was binding (fixed now!
so i ran in fwd for a while......
combined with skinny snow tires it equaled STUPIDLY easy wheelspin!!
(not that i did it often,since i didnt want to risk ruining anything...... )
fun in a childish way but ultimately kinda sucky when some punk kid in a riced out civic can kick yer butt from a stop light........
but once u are rolling..........oh yeah baby look out !!
i'm too svxy for my car
rob
92 ebony 4.44's rock !!
