Old 09-29-2007, 02:57 PM
nextse7en's Avatar
Graphic Artist
Probably the last question of the day...
Hi folkes, when I run my car, it overheats almost immediately - with coolent hissing out of where the water manifold meets the block on the passenger side - I've pulled the intake plenum and the water manifold. And am replacing the rubber o rings under the coolant manifold
Quick question - can a water pump immediatly fail? The fan system seems to be working fine, but the car got so hot it murdered the gaskets under the water manifold.
Should I check for blockages first, or water pump - engine has 150k on it.
-Patrick
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 09-29-2007, 03:23 PM
Manarius's Avatar
Manarius Manarius is offline
I wonder if there's a blockage...especially if water is seeping out near the block.
-Jason
-Obi Wan Kenobi
Old 09-29-2007, 04:03 PM
nextse7en's Avatar
Graphic Artist
Well, I just pulled the thermostat... It seems stuck closed... I really pushed down hard on the valve and it wouldn't open... I think I may have found my problem...
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 09-29-2007, 04:18 PM
JaySVX's Avatar
JaySVX JaySVX is offline
That could defidently cause the problem. If you open the radiator, and look in, you should be able to see motion if the water is flowing properly.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 09-29-2007, 04:24 PM
nextse7en's Avatar
Graphic Artist
Now all I have to do is put it back toghther
Fracking water manifold under the intake plenum - 4 hours of work just to reseal it.
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
