Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
Old 06-01-2007, 04:30 PM
longassname's Avatar
Just some dude.
Exhaust with no resonance
Ok, I just replaced everything forward of the factory muffler on my stock svx and can recomend the set up I went with.
  • 2.25" tubing all the way from the flanges that bolt to exhaust manifolds. Cut the factory tubing off at the flanges and reuse the flanges. The tubing in front of the flange that slides into the exhaust manifolds and is surrounded by a copper o-ring is much larger than the tubing after the flanges--it's something around 2.25".
  • oxygen sensor bungs in the factory locations
  • magnaflow/carsound 940xx cats in the factory primary locations
  • an 18" long dual in single out magnaflow muffler in the location where the factory dual inlet cat is
  • 2.25" tubing back to the factory muffler
That set up has absolutely zero resonance or under car noise and is quieter than the factory set up.
Old 06-02-2007, 01:29 AM
Nomake Wan's Avatar
Retired
Do you have an under-car shot of the setup? Sounds very cool.
Old 06-02-2007, 08:40 PM
Just some dude.
I didn't think it was anything special to take pictures of. It just so happens that these dual inlet magnaflow mufflers are the answer to the resonance problem on svx's.
I had speculated this a while ago and made plans to use the dual in dual out which is basically a corrugated x pipe inside of a resonance chamber on my dual exhaust car and the dual in 1 out which is basically a corrugated y pipe inside of a resonance chamber on my more stock car...I just hadn't actually proved it until now.
