Old 02-02-2007, 12:27 AM
pearlm30's Avatar
pearlm30 pearlm30 is offline
Trany Mount???
My 94 seems to have clunk/squeak sound coming from center of the car. Could this be the trany mount? If so, how can I replace it? Did the exhaust needs to come off?
Thanks
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD
92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD
92 Teal SVX LSL lowered with Konig. SOLD
92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone
94 Red SVX L FWDwith LSL Leather Interior. SOLD
92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD
95 Polo Green........With Trany Problem. GONE
Almost complete Rear Wheel Bearings Job with Pictures in my locker
My Locker http://www.subaru-svx.net/photos/user.php?pearlm30
Old 02-02-2007, 12:52 AM
svx-t svx-t is offline
Thanks
most likely it'll be your tranny mount...the exhaust might have to come off..im not too sure for svx's...but for impreza's...it should pretty much be the same layout...its pretty easy taking it off and on...under the car there is a transmission crossmember that sits under the tranny mount...the tranny mount is in between..just about...5 bolts and the crossmember should come off...make sure that you put a floor jack under the tranny..incase..
i had the same situation with my impreza..the only problem is that the stock tranny mount wasn't stiff enough to support the tranny and engine when shifting gears..
Old 02-02-2007, 10:20 AM
davew833 davew833 is offline
tranny mount-recent experience
I just did the tranny mount on my '95 LSi without removing the exhaust. I did remove the bolts from the exhaust hangers in the area of the mount so I could move the exhaust downward a little. I didn't remove the tranny crossmember either, just the six bolts that hold it to the car and the three nuts that hold the tranny mount to the x-member. I slid the x-member toward the back of the car until the tranny mount could be removed. It's a tight fit, but it worked. If your tranny mount's broken, it will likely come out in two pieces. You will also be able to tell if your tranny mount's broken without removing anything, by raising the car and pushing up on the tail of the transmission. If it moves up freely without much effort, it's your tranny mount.
davew833@yahoo.com
Former 6-time SVX owner
