Old 01-16-2007, 09:21 PM
floatingkiwi's Avatar
floatingkiwi floatingkiwi is offline
A flight-less flyer
Send a message via Yahoo to floatingkiwi
How to remove the rear view mirror.
Hi all
Does anyone know how to remove the grey plastic bit on the large shaft of the rear view mirror? It looks like it hides the bolts of the long shaft or something. I'm trying to hardwire a radar detector and don't want to rip the dash apart to come up from underneath. Will come down from the dome lights instead, but can't get a wire in there!
'92 JDM (E) Burgandy/Black 100Km
Just Crusin'
Old 01-16-2007, 09:48 PM
If I recall, you just yank on the mirror. It's made to break-away in event of an accident. Once it is down you'll see what you have to take apart to re-attach it.
Old 01-16-2007, 09:54 PM
davew833 davew833 is offline
It may be breakaway, but there are four screws under the cover that hold it into the ceiling. I wouldn't just yank it off unless you plan on replacing it. Get a thin-bladed screwdriver or knife to pry the plastic cover off.
davew833@yahoo.com
Former 6-time SVX owner
Old 01-16-2007, 09:55 PM
sharky512345 sharky512345 is offline
Send a message via AIM to sharky512345
I had to replace my rearview mirror after it fell off one time and if I remember correctly the plastic piece either slides or pops off then you can get to the screw underneath.
Current: 2005 Black Legacy 2.5i 63k
Previous: 1996 Brilliant Red SVX LSi 117k
Old 01-16-2007, 09:57 PM
Yes, this is correct. One can just pull the mirror (or have someone's face smash into it) to get it off. There is only 1 (one) screw underneath that is held on by a little metal clip which will move to allow the mirror to be taken off.
Old 01-16-2007, 10:13 PM
A flight-less flyer
Done. Prise the plastic bit off with a thin blade, then you can get to the screws. Cheers all.
Just Crusin'
Old 01-16-2007, 10:40 PM
Will the detector work through the front glass, with the titanium coating?
Old 01-16-2007, 11:28 PM
A flight-less flyer
Certainly seems to be, picking up neon signs left right and center! (Haven't tuned it for NZ yet!).Maybe it's only the US that has that coating?
Just Crusin'
Old 01-17-2007, 07:30 AM
cdigerlando cdigerlando is offline
Titanium Coating
Mine never worked well. Not in time anyway. Neither did my epass. Had to get a special external mount.
Chuck D.
1992 Subaru SVX LS-L - Heavily modded turbo
2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods
Old 01-17-2007, 03:59 PM
AlcyoneDaze's Avatar
<-- custom hood ornament
You need the license plate mounted ezpass for this car, learned the hard way $$$$$$
Radar detector works... with the window down
JDM 4.11 Geared Transmission
JDM 'ALCYONE' Rear Panel
JDM 'BOXER' Eingngine Cover
JDM 'SVX' Hood Badge
L-Edition Suede Rear Seats
Old 01-18-2007, 12:08 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Cool Sharky512345
Hey man - just checked out your car picture, your mags are on the wrong sides - down by valve stems on the rims you will see the letter "L" = fit to LHS (the RHS does not have any letter) - makes for better cooling to brakes & less possibility to warp those brake discs........that's what happened to mine.
Steve in New Zealand
Old 01-18-2007, 12:15 PM
SURTEESS's Avatar
GPS & window coating
Floatingkiwi - had to use an external GPS antenna to get my Navman iCN635 to work in the car (attached antenna to inside trunk lid) - fitted unit in the dash pod area (out of sight). Some NZ new cars came in with the mettalic window coating film.
Old 01-18-2007, 01:23 PM
A flight-less flyer
Nice leather seats! What product do you use on the fake wood trim? Looks nice.
Mine is a jap import, so I suspect no film. Also it has been detecting all the neon signs!
Just Crusin'
Old 01-01-2011, 12:29 PM
David David is offline
Re: How to remove the rear view mirror.
I picked up a gray auto dimming mirror for $3 yesterday at pick-a-part and am trying to install it, but can't seem to get the plastic piece covering the screws to pop off. Have managed to slip a thin putty knife all the way around, but so far can't get it loose.
Any helpful hints..??
Old 01-01-2011, 01:52 PM
kwren's Avatar
kwren kwren is offline
It just snaps off... "get a bigger screwdriver"
Keith
