Old 01-07-2007, 07:18 AM
95greensvx's Avatar
95greensvx 95greensvx is offline
Purge Control Solenoid
I recently checked the codes due to my check engine light coming on and I got a code for a Purge Control Solenoid and I am not quite sure where this is located at on my car. If someone could point me in the right direction that would help me out greatly. Thanks in advance.
Old 01-07-2007, 01:59 PM
You will find a black canister, engine compartment, front left, with two flexible tubes connected to it. Follow the tube going towards the engine. It is connected to the Purge Control Solenoid valve at the first connection point.
Old 01-07-2007, 03:59 PM
95greensvx's Avatar
I just went out and looked and are you referring to the black canister, front left engine compartment, next to the radiator? That has two tubs running out but both run into the engine and underneath the tops of the intake manifold, if that is it then I'll look further tomorrow when it's light out. Thanks.
Old 01-07-2007, 04:58 PM
Yes, you are on the right track. I agree things are rather obscure and you will need good light.
Old 01-07-2007, 05:01 PM
DarknessofDeath's Avatar
Inhabitant of Darkness
isn't that the one under the manifold itself? i had to replace that one. costs $$
Old 01-07-2007, 05:19 PM
It is certainly hard to get at and you are probably right.
Old 01-07-2007, 05:34 PM
95greensvx's Avatar
Any ideas as to where I can purchase a purge control solenoid? Assuming I am in need of one. Thanks.
Old 01-07-2007, 06:10 PM
The PCSV simply draws of fuel gas/fumes collected by charcoal within the canister. A continually open valve could cause a problem, but do you have poor running simptoms? If so the inlet to the valve could be blocked off, provided that you are not overly concerned in respect of the environment.
Old 01-12-2007, 11:01 AM
i thought i had an extra from replacing the engine recently but i didn't find it on the engine taken out, ****'n bastards probably kept that as well as other things. sorry i can't help you out.
try subaruparts.com or i think a lot of other guys prefer 1stsubaruparts.com . i'm not sure if that is correct. but it's osmething like that.
or try posting in the wanted/forsale thread in items wanted.
Old 01-21-2007, 02:48 PM
95greensvx's Avatar
Is anyone aware if this:
http://www.subaruparts.com/diag/?mod...ategory=082A-1
is the same as the purge control solenoid? Thanks in advance.
Old 01-22-2007, 12:09 PM
it looks like it to me
Old 01-23-2007, 12:33 PM
Speedklix's Avatar
Locker Link Solution
Mine came that way!
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 01-23-2007, 02:33 PM
Thats not what you are looking for. That it merely a connector to the crankcase breather system...
Old 01-23-2007, 03:54 PM
95greensvx's Avatar
Ok, I am just not completely familiar with the complete engine layout of my SVX yet so I'm still trying to locate where it is positioned on my engine. If I can find a Chilton's manual for my SVX this weekend then I'll go that route as to locating it. Thanks.
Old 07-22-2009, 01:49 PM
Mike Mike is offline
Re: Purge Control Solenoid
There is a third hose attached to the bottom of this canister. Mine goes no where, do you know where the other end of this hose attactes to?
