Old 12-12-2006, 01:48 PM
davew833 davew833 is offline
Swap a '92 ECU with a '95?
OK- so here's a follow-up question to my ECUTune chip removal q. Can I swap my '92 LS-L ECU with the Stage 1 chip into a '95 LSi? My instincts tell me there's probably enough differences to make it impossible.
davew833@yahoo.com
Former 6-time SVX owner
Old 12-12-2006, 01:58 PM
Manarius's Avatar
Manarius Manarius is offline
Your instincts are right. OBDI to OBDII is a bridge that most people try to stay away from.
-Jason
-Obi Wan Kenobi
Old 12-12-2006, 01:59 PM
Is '95 OBDII? I thought that started with '96?
davew833@yahoo.com
Old 12-12-2006, 02:01 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Most if not all 95s aren't OBD-2 or at least mine isn't (build date of 11/95) or any that I've looked at in yards over the years. Not sure if it would work or not but I'm guessing it probably would work with some effort unless you're a obd-2.
Old 12-12-2006, 02:10 PM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
It works fine, I have my '92s ECU in my '95 right now and it drives just fine. ODBII started with '96s.
dustin
-Dustin
Old 12-12-2006, 02:22 PM
Manarius's Avatar
dustin
Hmm. In the Legacy, OBDII started in 1995.
-Jason
-Obi Wan Kenobi
Old 12-12-2006, 02:28 PM
I can also confirm that the reverse is true: a 95 ECU works in a 92 SVX.
