Old 01-15-2007, 01:45 PM
The groupN mounts are meant for sti's. They need to be fitted into the SVX brackets and are a cheaper replacement for torn stock mounts or an excellent upgrade
Check the link in my sig for info on the mt kits...
Thanks
Old 01-19-2007, 01:22 PM
Hey all. I picked up a $35 trans from Harry's U-pull it the other week. Stock SVX auto. After disassembly, everything looks to be in good working order and it very well could be reassembled and put in a car. Screw that... I wanted to take a crack at rebuilding an auto even if it was just to see if I could do it. So... if I do go ahead and rebuild it, it would get a level 10 kit or better. Would anyone be interested in buying it?? I also wanted to ask if people think I should start rebuilding these and keep them on the shelf for when they need one? Thanks for the input
Old 01-19-2007, 01:26 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Tom,
It would be even nicer if you could "beef up" 4.11 and 4.44 ATs. I still believe that the 4.11 is the best all-around gearing, it just doesn't seem like they want to live behind the EG33
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 01-19-2007, 01:53 PM
I can put 4.11 gears in an SVX auto... Just give me the 4.11 tranny
Old 01-19-2007, 06:12 PM
Bill, BTW I know whats going on with your pearly and whole parking prawl situation... If you can get up to philly sometime I will take care of it.
Old 01-19-2007, 07:24 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
What you can fix driver error? What are you gonna put blinders on the car so it can't see brick walls?
Old 01-19-2007, 08:38 PM
actually it was a foolish mistake I had made... Not earth shattering but it should be fixed
Old 02-15-2007, 11:55 AM
bump... Had a couple people ask about the Group N mounts lately so i figured I would make it visible
Old 02-15-2007, 02:11 PM
SVXRide's Avatar
man, that's just harsh! (the pearl will only be street driven )
-Bill
Old 02-15-2007, 02:13 PM
SVXRide's Avatar
Tom,
Does it have to come to Philly for the fix? I'd like BillStock 4.0 to be the guinea pig for your "other effort"
-Bill
Old 02-15-2007, 02:23 PM
benebob's Avatar
-Bill
Well ya know its like the old saying goes... If ya can't beat the competition might as well crash it.
BTW. $2006 issue of Grassroots should be hitting the stands any day now. Got mine last week. Its the April issue and has a blue alfa on the cover. At least coming in 25th had a bright spot. We're at the top of a page!
Old 02-15-2007, 07:33 PM
Tom,
-Bill
I have to take the rear housing off and take off the sun gear on the front pinion... there is a small shim that needs to go in there... I found pics ofyour trans while I was putting it together with the new diff and I missed something. If the weather is nice at reading we can do it there at the same time I convert the racer to 5mt... Should be able to squeeze it in Unless you find some time to jump up to the shop and I will take care of it.
Old 02-15-2007, 08:33 PM
SVXRide's Avatar
Ben,
fantastic! I'll have to check out the local Borders, as they're the only one that carries GRM.
-Bill
Old 02-15-2007, 08:35 PM
SVXRide's Avatar
Tom,
Sounds like a plan. Give me a call next week so we can follow up on your PM.
-Bill
Old 02-15-2007, 10:19 PM
I will know more once Mike can give me a quote
