Old 09-29-2006, 07:52 PM
GOT2HAVESVX's Avatar
GOT2HAVESVX GOT2HAVESVX is offline
What blue lights?
Send a message via AIM to GOT2HAVESVX
Question Svx Steering Locked..????
OK I drove my car to work today and everything was fine. I came home and parked it in the driveway and when I went back out about 7 hours later when I tried to start it I couldnt turn the key and the wheel was locked way past (like 1/4 turn) where it usually is. I tried a few times and wiggled the wheel and it finally sprung loose and I started it.
Can anybody tell me what might have happened and if its something bad?
Life begins around 70 MPH and stops when you dont see the flashing blue lights anymore!
Scott & Audrey's Subaru SVX's
1995 Green
1992 Black
Old 09-29-2006, 08:20 PM
AFBeefcake's Avatar
Subaru Swapper
Try turning the wheel a little and the key will then turn.
2005 Legacy GT
My WRX's Cardomain Page
Old 09-29-2006, 08:50 PM
Most cars are like this.
Old 09-30-2006, 06:27 AM
What blue lights?
It wasnt like "most cars" though. I have drove quite a few in my years of driving but this wasnt the same. It was locked way past the normal position that it usually is. Just thought it might be something I havent read about a SVX, guess it was just something weird. Thanks for replying...
1995 Green
1992 Black
Old 09-30-2006, 07:20 AM
svxthc's Avatar
svxthc svxthc is offline
make sure the vehicle is in park, mine wasnt one time
1993 SVX Anniversary Edition #64
Old 09-30-2006, 09:55 AM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
Parked on an incline? Could it have rolled a little back to bind it 1/4 more?
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 09-30-2006, 12:15 PM
What blue lights?
Theres a slight grade all the way down my driveway and it levels off before you pull into the garage, maybe thats what it was, it was definately in more of a bind then its supposed to be, I have had a lot of cars, (including 2 drag cars) but since this car is so much different then anything Ive owned, I thought I would ask. Now, I am going to change the oil to a castrol synthetic and maybe start some body work, the shop should be open in the next week or 2 so I can get it painted! YAY
1995 Green
1992 Black
Old 09-30-2006, 05:46 PM
Manarius's Avatar
Manarius Manarius is offline
If the key goes in and won't turn, it's not parking lock, it's the steering wheel lock. The locks on the older cars take a bit of turning to engage, much more than just a few inches like newer cars. However, the method of disengagement is the same. If you come to the car and stick the key in and it won't turn, turn the wheel a little bit more the direction it is turned (like an inch, maybe), this releases the tension from the locking mechanism to let you turn the key to start the car.
-Jason
-Obi Wan Kenobi
Old 09-30-2006, 06:10 PM
What blue lights?
Thanks, I figure this is what happened now & because of the grade into the driveway, it was just turned further then normal...maybe. (who knows!) Thanks for the help!
1995 Green
1992 Black
