How do you install a battery tiedown and tray?
Ok so my battery doesnt hold charge anymore... been about almost 2 years since I bought the SVX. It didnt come with a tray or tiedown and I didnt know it would affect a batterys ability to hold charge (I used a bungee deal) until I did a search and found it loses charge without a proper tie. Is it really necessary to get a tray? Is there an alternative, like a piece of plastic or something.
Also, how do I install a battery tiedown? I have not the slightest clue where to start.... I tried looking for instructions on here but came up with none. I would prefer a tiedown from kragens or something I can get.. I cant cut metal as I have no tools to drill nor cut, I only have wrenches and such. can someone help a noob? :O i dont want to blow money on a new batt and have it go out in 2 years. |
Hey go to Subaruparts.com and you can order the following parts:
You need 1) 82182AA30 - Battery holder bracket (1) 2) 82161PA000 - J Hooks (2) 3) 82122PA000 - Battery tray (1) 4) 023706006 - J Hook nuts (2) Place the battery tray into the frame area it sits on....place battery on top, then set the battery holder bracket on top of the battery....you will picture how the J hooks fit from this... Take the J hooks and hook the "J" part to the car..under the battery tray..(there will be a small hole to hook it to) do this on both sides...so then the J hooks will have the threads upward coming through the holder bracket on each side of the battery. Last run the nuts on each hook....you may have to wiggle the battery to get it set just right between the hooks..... That's it...then rehook up you positive and negative connections and make sure you have a good ground from the negative properly attached to the metal on the frame.... Also make sure your connections are clean and no buildup on them. You could be getting some bad charges because the connections may be corroded...Try a wire brush. Does that help? |
Yea, thanks a bunch! I was hoping to find a solution that didnt involve me ordering stuff online but ah well. Thanks!
You can get universal tie down equipment for your battery at most auto parts stores Pep Boys, Advance Auto, etc.)
The tie down "J" or "L" bolts and nuts come in one package. Thet are usually 1/4"x20 and are threaded at one end. They may have to be cut a little off the end to make sure they don't kit the hood. If there are different lengths available, get the shortest length you can find. The battery brackets are universal and fit most standard battery widths (which is just under 7") The only thing you would have to get from Subaru is the battery tray. This also secures the battery and keeps battery acid from coming into contact with the frame. The tall side of the pan (faces the engine) has a built-in guide for the bolt to slide through to further secure the battery pan against movement.) Don't skimp on this part. The battery pan by itself is about $14.00. You should be able to get everything you need OEM for about $36.00. Someone here may have spares. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 09-22-2006 at 10:32 AM. |
Ah I see how it works now... thanks alot!
Thread Tools | |
Display Modes | |
