MAF sensor or AMF sensor
I found this in my surfing around and was wondering if the SVX is in this same
catorgory or is there a difference in AMF and MAF Yes the AFM has a self cleaning circuit. As the AFM is a hot wire type in normal operation it has a constant 5volts running through a resistance wire,air passing this wire cools it and changes the resistance,hence changing the output voltage. The ECU moniters this output voltage and establishes the amount of air entering the engine from this value. When you turn the key off, you may here a relay shut down after about 5-8seconds later. In this time the ECU has supplied a higher voltage (often 12v) to the AFM resistance wire which will make it glow red hot momentarily and clean off built up deposits. Self cleaning. Clever aye! Rob Bryan WAR Motorsport |
Our cars have MAF sensors. They don't self-clean.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
