Old 07-23-2006, 10:44 AM
Manarius's Avatar
Manarius Manarius is offline
Legacy Issues
Maybe someone here with some mechanical background can help me out. Basically, my Legacy is undriveable. It's been sort of a progressing matter, getting worse up until the past two or three days where the car is not driveable.
Car: 1991 Subaru Legacy L AWD 2.2l MPFI 151,000 miles
Symptoms (all occur at or close to normal operating temperature; none occur when car is cold):
Unable to idle
Randomly dies out while driving along
Bogs to the point of stalling out when trying to pull out onto a road (ie, I press on the gas and the car just stalls)
After said point of stalling, the car will refire, but then just shut off
At some points, it is completely unresponsive to the throttle (ie, I press on the gas and the car does nothing...except shut off; part of the shutting off at road speeds)
What I have replaced: Knock Sensor, Coolant Temp. Sensor, Plug Wires, Fuel Filter, Plugs.
I have reset the ECU. And part of the reset is that you have to make it 'relearn', yet when it gets to operating temp, the car just stalls out when it's idling there (car is supposed to just idle until it reaches operating temp to 'relearn'). The car did throw a code before I reset the ECU for the MAF (which I have on order), but since the reset, it hasn't thrown that code.
So, what's wrong with it? I hope that the MAF fixes it, but I'm hitting up all the forums I'm on to see what other people may have in mind (here especially because there are some ASE certified techs on the board).
Thanks in advance,
Jason
-Jason
-Obi Wan Kenobi
Old 07-23-2006, 11:30 AM
demonsvx's Avatar
demonsvx demonsvx is offline
building more AK47's
I had the same problems after I replaced the timing belt. Found out I was one tooth off on timing had it fixed and problems went away.I hope this helps
1992 SVX LSL Ex wifey has it now pending self destruction 2001 Legacy mods to come 1992 Subaru Legacy 2.2 214k Boob wheels CANT KILL IT
Old 07-23-2006, 12:21 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
intresting thing about these cars... unplug the MAF and see if the problems go away... (it will go in to a fail safe which runs off of set paramaters insteed of what the MAF is telling it) and check to see if your air filter is in right... trust me i have seen these problems before because the air filter was in wrong...
- John
Old 07-23-2006, 01:01 PM
subeman90's Avatar
Soobologist
bad fuel pump? I had a car that would run fine when cold but after some use the think was a total dog. The FP would lose pres. after it was run for awhile and...well you get the point.
15 OBW premium w/eyesight
Old 07-23-2006, 01:23 PM
Speedklix's Avatar
Locker Link Solution
I'd just wait for the maf... many 2.2s won't even start when they go bad.
I can't remember if what suby fan says is true, but you could give it a shot. I think last time I tried that on a 2.2 it didn't work, but I could be mistaken. That car needed a maf, and acted as you described... good used maf made it run like a top again!
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 07-23-2006, 01:39 PM
Manarius's Avatar
I'm pretty sure I tried this and the computer just threw a CEL and ran like crap. I mean, it's worth giving a shot again if it would let me drive the car at least without having to worry about it stalling out. ::EDIT:: Tried without MAF. Car wouldn't even idle. It would start all right, and unless I hit it to go on low idle, it would just shut off. If I did hit it on low idle, it would idle for a little while, but then eventually would shut off.
I thought fuel pump as well at first. But, I'll be damned if it isn't one of these sensors. I've been told though that usually, if the fuel pump is crap, it just stops working, it doesn't kind of crap out on you, but I may have one like you have.
I really hope it's not a timing belt. I can't afford that job.
-Jason
-Obi Wan Kenobi
Old 07-24-2006, 01:10 AM
One of my old GL wagons acted like that. The cat was so clogged that when it got hot, it completely blocked off the exhaust...
Loosen the bolts in the exhaust in front of the cat, that will allow the exhaust gas to get out even if the cat is clogged. It will be loud, but it's a cheap way to see if that is the problem.
Old 07-24-2006, 01:32 AM
Speedklix's Avatar
+1 for this. This would be the next thing on my list too! after MAF
In fact one of my 2.2 soobs needs a cat now, and acts like it wants to stall while leaving the driveway. I just have not had the time to deal with it yet.
it should have thrown a code for it before getting that bad, but who knows. Make this your next item to check for sure!
-Mike
[SIGPIC][/SIGPIC]
Old 07-24-2006, 08:17 AM
Manarius's Avatar
Ok. I'll try that after the MAF if that doesn't fix the problem. I mean...perhaps that could be the issue if the problem got progressively worse(like, I noticed a small power thing back over a month ago, but it went away until within the past two weeks). Weird thing is though is that I haven't really noticed a decrease in Exhaust pressure...the flow at the muffler is still pretty good.
-Jason
-Obi Wan Kenobi
Old 07-25-2006, 02:40 PM
Manarius's Avatar
Seems to have been the MAF. I put a known good one on and the car drives like brand new.
-Jason
-Obi Wan Kenobi
Old 07-25-2006, 04:37 PM
Speedklix's Avatar
I figured...
Woot! <--can't believe I actually typed that
Glad to here you're rolling again. It is amazing how touchy the 2.2 is with the MAF!
-Mike
[SIGPIC][/SIGPIC]
