Old 07-23-2006, 10:00 PM
Speedklix's Avatar
Locker Link Solution
Yeah, not a good move. Even when I'm just doing something quick and not even getting under the car I throw the tire under the side at the nearest factory jack point.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 07-23-2006, 10:02 PM
Originally Posted by Manarius
Uhh..not usually. I only use the aforementioned method when swapping tires. Although, occasionally I pop under there to look at something.
I know you're not supposed to do that, but I bet more cars have fallen off of 'real' lifts than off of floor jacks (by either failing or rocking).
Cars do not fall off real lifts. If they did legal matters would be involved. There is no excuse for taking these risks. If you can't afford to purchase stands, use building blocks or whatever, but only with care and knowledge of the strength of the objects used.
When changing a wheel for the spare, place the spare tyre under the car at the lowest point. If the jack slips, say on uneven ground, the wheel and tyre may prevent damage and hold the car high enough for a second attempt.
Old 07-23-2006, 10:04 PM
Speedklix's Avatar
I'll take that bet, you have to be real bad to drop a car on a lift.
I've seen the mess after it happened once (a serious genious in his friends shop), but at least once a year I see that a kid has died nearby under a car supported by a jack
-Mike
[SIGPIC][/SIGPIC]
Old 07-31-2006, 01:12 PM
Mr. Pockets's Avatar
Moderator
You're really going to trust your life to an unconfirmed, arbitrary assumption like that?
Go get more jackstands and please don't get under your car when it's supported by a jack.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 08-01-2006, 04:48 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Originally Posted by n00b on demand
I'm using a 2 ton floor jack from sears. I tried to shove the jack under the car and tried to use the subframe to jack it up but you cant pump the handle because it keeps hitting the bumper.
I always have the same problem....I'm thinking about digging a pit in my garage floor next....roflmao
1995 Subaru Svx L / AWD
Old 08-01-2006, 09:34 AM
SVX33 SVX33 is offline
I have four 2 by 6 pieces about a foot long that I drive up on. Makes it easy to get the jack under with room to start pumping. Also I always use the subframe to place the jack stands and have had no problem with getting around under the car.
Old 08-01-2006, 11:21 AM
if someone could post pics of the appropriate places to jack up the car, and perhaps a picture of an svx properly set on stands that would speak a thousand words!
Old 08-01-2006, 05:08 PM
Speedklix's Avatar
I know I have at least one pic somewhere at home of mine during the swap. I'll see when I get home.
-Mike
[SIGPIC][/SIGPIC]
