Old 05-11-2006, 03:58 PM
svxpassion
Rim size/backspacing... help!!
Can someone provide me with the backspacing range that will fit the svx.. I "NEED" some 17" rims. Someone said anywhere from +38 - +48 will fit.. is this true?
Old 05-11-2006, 04:40 PM
mbtoloczko's Avatar
sans SVX
Yes, For 17x7", +38 to +48 is fine. For 17x7.5", +42 to +48 is fine. For 17x8", +45 to +55 is fine. I'm assuming that the proper size tire for each rim size is used.
17x7" use a 215/45-17
17x7.5" use a 225/45-17
17x8" use 225/45-17 or 235/45-17
Mychailo
Visit my locker
