Old 05-04-2006, 04:02 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
I only ran 15.7@89.45MPH with stock gears&flaring, majorly screwed up exhaust, dying MAF, Spare removed, 1/4 tank of gas, and about 60 degrees out.
I suspect I'll do a little better next time out.
Old 05-09-2006, 06:55 PM
rmjjensen's Avatar
rmjjensen rmjjensen is offline
Send a message via AIM to rmjjensen
I want to run my SVX 5-speed so badly!!! Hopefully I can go sometime real soon.
So ...what should I expect from a 5-speed SVX?
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing
5-Speed Status: DONE!
Lambo Door Status: On hold but will be a success
04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk.
The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash
Old 05-09-2006, 07:39 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
John (AvPPoW) ran a 16.2 or so. TomsSVX ran a 14.8 w/o cams. You'll probably be somewhere in between.
2006 Steel Gray WRX TR (sold)
Old 05-09-2006, 07:42 PM
rmjjensen's Avatar
Follow up.
Whats the best way to launch the 5-speed SVX? I tried a clutch dump at 5k or so and the clutch was not very happy. It seemed to like 2,500-3 a lot better and smoother. Any other comments on this?
Old 05-09-2006, 07:50 PM
Chiketkd's Avatar
Follow up.
Launching at 5K rpms will definitely heat up your clutch quickly and cause it to slip. However, if you launch too low in the rpm band, your engine will bog, and the 'strain' will be placed on your trans.
Best thing to do it pump your tires up to 40psi all around, and try launching at 3.5-4K rpms. That should be enough to spin the tires briefly so that the engine doesn't bog and as little strain as possible will be placed on the trans.
