Old 03-14-2006, 04:43 PM
NoName NoName is offline
FastandFurious
security question
where is the dashboard security on/off switch
I look all over and can't find it
can someone help with a picture or something
94 svx lsi
http://www.subaru-svx.net/photos/files/How-To/27326.pdf
Old 03-14-2006, 04:53 PM
dwd1985 dwd1985 is offline
It is on the left side of the steering wheel. There will be 3 buttons next to each other. The cruise control activation button, the fog lights, and closest to the steering wheel, the security switch. When the system is active, the red light will blink. When it is inactive, it will stay red the whole time.
Old 03-14-2006, 06:00 PM
If yours is a Canadian SVX then you don't have a security system.
Old 05-10-2006, 07:58 AM
AJ4U2's Avatar
AJ4U2 AJ4U2 is offline
Question Security
I have a problem with mind, My light stays on and will not blink or set, when i push the buttom in the light goes out but will not arm. Is there a fuse or relay or do i need to replace the module behind the glove box, 1992 model, it was working until i unhooked the battery and when i try to reset the remotes is when it mess up,
Old 05-10-2006, 08:33 AM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
have you reporgramed the FOB to the car?
- John
Old 05-10-2006, 09:33 AM
AJ4U2's Avatar
fob
It won't go in the set mode to do that, the light stays on will not blink at all, when i push the buttom in the light goes out, it acts like a relay is stuck in the open position or someting in that effect.
Old 05-11-2006, 07:26 AM
AJ4U2's Avatar
Location
Is there a relay besides the control module with this security, and are all 1992 behind the glove box, I would hate to have to pull all this out if there is somewhere else to look for fix. or is it better just to get a aftermarket one to replace this one, what type is the easier to do, don't need the remote start, just the lock and unlock with sound.
Thanks if anyone can help
Old 05-11-2006, 12:49 PM
AJ4U2's Avatar
Smile Quote
Well there is a fuse in the module, 2amp buss type and it was blown out so all i done was replace the fuse and wella fix, glove box was not all that bad.About a 35 minute job, not bad for a senior citizen.
