driven wheel
There are two things that are giving me great misery. One is the valve cover gaskets on my svx and the second one that is the main pain is the driven wheel on the speedometer shaft. Is there a business that sell the material that you can make the valve cover gasket out of (looks like o-ring material)and how big of a job is it to replace the driven wheel on the speedometer shaft. Help.
The driven gear, I've been through.
I thought I would be able to get to it through the front differential without removing the transmission. It turned out impossible to do... And believe me, I tried! I ended up having to take it to Subaru. They have to remove the transmission, and set it on a bench to replace those little plastic like gears (as a set). They then of course re-install the tranny. They charged me $990 to include the two gears. Since the labor is so intensive, they obviously suggested replacing them both, which I of course did. I think both gears cost like a 20 spot. If anyone could pull off replacing the gears without removing the tranny, it would be Tomssvx. If he doesn't rhyme in, I would PM him. I myself could NOT pull it off after extreme effort to reach them through the differential.
Robert Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me. Update: 09 January, and still not in jail! Wassup?? 1992 Teal LS-L - 160k (Now new and improved with perfect paint!) |
Welcome to the site. Hope you can get your problem fixed.
I do seem to recall people "making" the rubber grommets that hold the valve cover on... edit: I forgot about the inner seals around the spark plug holes, so you looking about $27 per side
Dave - 03 Baja - 92 SVX - 86 Brat - 08 OB 3.0 Last edited by Hocrest; 02-11-2006 at 07:50 PM. |
Do you need the small gear or the big ring gear for the speedo?? If it is the big ring gear, it is possible to do without removing the trans. You need to be very mechanically inclined to do it though
tom |
Re: driven wheel
will be done in the car, just like when i did the dirven gear drive gearon my legacy when it burned up. At least that one is cable driven and no shaft replacement. All of this wil be done with it still in the car. trust me it was pretty hard in the Legacy, this will be similar i am up for it. LOVE>
1985 Brat GL 138k 91 CRX Si 40k 91 CRX Si 155k 97 SVX Lsi 70k 2003 s2000 91 RT4WD 166K |
Re: driven wheel
Pics or it didn't happen! I was told it wasn't possible.
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
Re: driven wheel
What cost $54.00 in 2006 now costs about $120.00, discounted.
