Old 12-12-2005, 03:45 PM
neptue's Avatar
neptue neptue is offline
Should I Buy the tool?
Hi,
I'm in middle of decision that I should buy the
crank pulley ranch. It cost $150 from Subaru specialty tool store.
What do you think?
Is it really hard to remove the bolt on crank pulley?
I dont' know big flat screw driver holds the flywheel.
Any experience with that?
Old 12-12-2005, 04:17 PM
This tool?
Old 12-12-2005, 04:20 PM
dromano's Avatar
dromano dromano is offline
Originally Posted by neptue
Hi,
What do you think?
I used a small pry bar, had to buy a 22mm socket for the bolt that holds the pulley. I was so worried about the torque on the bolt when putting it back I used thread lock. Will need to be heated to 500 degrees to break the lock!
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 12-12-2005, 04:39 PM
neptue's Avatar
exactly that tool, but they discountinued one you posted and have a replacement.
Originally Posted by svxcess
This tool?
Old 12-12-2005, 04:43 PM
neptue's Avatar
Do we have to heat up the bolt?
How? Don't tell me to light up the car with news papers.
So, how was taking out the bolt?
easy? Hard?
How did you secure the crank shaft to turn?
Thanks.
Old 12-12-2005, 04:54 PM
immortal_suby's Avatar
Thread Killah
You do not have to heat up the bolt. He used a threadlock paste so he will have to at some point.
It is fairly easy, if you have the right tools, to break the bolt free and torque it back down.
Locker Link
2015 BRZ Limited 6MT
Old 12-12-2005, 06:14 PM
neptue's Avatar
What right tool?
Which tool is the right one?
Flat screw driver?
Old 12-12-2005, 07:37 PM
To break the crank bolt loose, put a 2' pipe on a 1/2" breaker bar (to make it longer) on the nut with the pipe touching the ground on the drivers side of the car(sort of below the battery), then get in the car and crank the motor over, presto! it's broke loose, no special tool to buy....
Old 12-12-2005, 07:51 PM
dromano's Avatar
A pro mechanic told me this is the way he uses to undo the crank pulley bolt ,,,OK you guys!!!!!!!!!! Standing too close could be hazzardous to one's health!!!!!!!!!!!!!!!!
Old 12-12-2005, 07:52 PM
kuoh kuoh is offline
Remember to turn the key all the way back to OFF right away, just in case your engine only takes a light touch to start.
KuoH
Old 12-12-2005, 07:53 PM
No problem, since you will be inside the car when you crank it
Old 12-12-2005, 08:54 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
Have you actually done this? I mean you do realize half of us will do this now. You better not be jiving us!
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 12-12-2005, 08:56 PM
I'm sure he has, several of us have from back in the Yahoo days. I've done it twice myself, though you still need a strap wrench to tighten it back up or else you risk the bolt loosening and causing a big problem.
KuoH
Old 12-12-2005, 09:12 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
I have done it a few times...works good, just remember to shut down right away...
'20 Honda Ridgeline
http://www.x35design.com
Old 12-12-2005, 10:28 PM
intelisevil's Avatar
<<<Alcyone
KuoH
Can't you just hook the battery up backwards?
Dan
