Follow the lines from the powre steering pump!
The hose starts at the PS pump reservior, and IIRC, it works its way down by the left side of the radiator.
Return line for Power Steering question
Hi,
If it runs from the pump res down to the rad then how can it drip down on to the left side of the manifold and steam up? Could the leak be coming from somewhere else? Sorry about the pics I didnt have much room with the car jacked up Im just glad that they were in focus. chris |
One of the most common leaks is the O-Ring under the tank. Look at the How-To Docs to find out how to do this. Next, the high pressure hose could be leaking. It is very common for that one to leak as well. It goes down the side of the engine. Hope one of those things are the problem.
Kidding about the picks! Was surprised you got them as good as you did
I had the issue that both my PS hoses (come from the PS pump - cooler and cooler - PS rack) were leaking about a month ago.
The cooler is just a long U-shaped pipe underneath your AC condenser (hidden by your radiator) and the connections to it are located on the passenger side. I just happen to be looking underneath at my newly replaced valve covers gaskets.. leaking and noticed the ps lines were starting to leak too. So I just replaced them with some 7/16" Goodyear ATF hoses and universal clamps (the originals looked a little rusty) from Autozone. I haven't seen the PS leak return but I'm noticing the valve covers are dripping oil onto the lines.
Marisa '93 LSL Anniversary Edition - 02/93 - 150,998 Daily Driver - Forged EG33 (long block), 6MT swap, and re-upholstered interior '92 Pearl - 100k Side restoration project Locker | Old Locker | Shutterfly | ReadingIX | Facebook | Instagram Last edited by cozykat; 10-08-2007 at 04:12 PM. |
Thread Tools | |
Display Modes | |
