Old 10-10-2005, 07:49 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
tranny cooler
I've been reading that many SVX owners have installed a tranny cooler. I bought my SVX with a rebuilt trans and never had a problem with over heating ( I drive 200+ miles a day) Do I need one installed? What is the advantage?
Old 10-10-2005, 07:56 AM
If yours is a 92 or a 93, the tranny cooler is a must. If a 94 and above, you have the option of either install one or not. It is up to U. But paying $100 max is better than paying $4000 for another tranny rebuilt...
Old 10-10-2005, 05:36 PM
dannmarr's Avatar
I work for my SVX
Where can I pick one up?
Old 10-10-2005, 06:29 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
How do you know unless you have a tranny temp gauge? The engine temp and tranny fluid temps are totally different. My guess is you have issues just from where you live. Just do a search of tranny coolers on yahoo for the workings of one and why it helps a transmission. Then do a search here for tranny coolers there is TOO much info to sort through.
Old 10-10-2005, 10:00 PM
dannmarr's Avatar
I work for my SVX
[QUOTE=benebob] My guess is you have issues just from where you live.
Can you please elaborate on this?
Old 10-10-2005, 11:23 PM
benebob's Avatar
[QUOTE=dannmarr]
Hills! Changing gears tend to heat her up nicely. Do a search on tranny temps and all. I'd personally recommend a tranny temp gauge and a large external cooler for ya as would 99% of all the SVX owners here. I typically run 100 degrees above outside temp. on WITH a big cooler on mine WITH NORMAL TRAFFIC DRIVING which puts ya up in the flash point (where tranny fluid will break down and starts killing your tranny above 90 degrees outside.
Old 10-11-2005, 12:47 AM
Alycone's Avatar
Alycone Alycone is offline
Sue isn't really striped
Generally a good idea to get a temp gauge and cooler, I got my gauge from motorsports: http://store.yahoo.com/svx-motorsport-accessories/ . Its nice to be able to see what the tranny temp is doing, like when it spikes going over a mountain pass. The cooler was just essential. I dont have a filter, but a lotta folks like adding em too.
Still in love with my Subie
Old 10-11-2005, 04:55 PM
The Goat The Goat is offline
Specifically?
National Auto Stores
Address: Route 940 & Route 115, Blakeslee, PA 18610
Phone: (570) 643-6995
I'm looking into them, too - the B&M cooler seems to be the way to go.
(Or you can order one through the Motorsport-svx on here - planetsvx.com, if I'm not mistaken.
Old 10-11-2005, 06:54 PM
benebob's Avatar
Originally Posted by The Goat
Specifically?
summitracing.com has everything you'd need as well, any local auto store will also have 'em but most of these places have the tube design which doesn't seem to cool as good from my understanding.
Old 10-11-2005, 07:41 PM
dannmarr's Avatar
I work for my SVX
Thanks for all your replies! I noticed all types and sizes of coolers. Which one does the best job for the SVX?
Old 10-12-2005, 07:34 AM
svxcuseme's Avatar
svxcuseme svxcuseme is offline
5 speed 4 sure
B&M cooler BMM-70268
I used the B&M (BMM-70268) mounted in front of the A/C condensor, behind the bumper. Size is perfect. I had to grind a little on the inside bumper so it would not scrub on the cooler but that was not really necessary. I'm a perfectionist. You can barely fit this one in with no mods.
If you plan on mounting it in front on ther ciondensor, I would'nt buy anything larger. You will have a hard time making it fit.
As far as how it works...no idea. I added a temp gauge and tranny filter but did'nt like them so I took them off. Never got any baselines.
Good luck!
EDIT: Here's a link to this part on Summit Racing's site.
http://store.summitracing.com/defaul...=egnsearch.asp
Old 10-12-2005, 08:47 AM
benebob's Avatar
That's the thing I don't think anybody has really gotten a true baseline by installing prior to the cooler.
Old 10-12-2005, 01:01 PM
Whoru465's Avatar
Whoru465 Whoru465 is offline
The name's...
Send a message via AIM to Whoru465
I think I read baselines somewhere before when I searched this very same question. Although, like somone else said, that's a lot of information to sort through. However, I wasn't having problems with my car, but I installed the cooler anyway...A little peace of mind. Good luck.
-Mike
'92 Pearl LS-L (sans Spoiler) #0993 Mfg. 5/91
"It says here, 'Breakfast any time'...
That's right...
In that case, I'll have the pancakes in the Age of Enlightenment..."
Old 10-12-2005, 01:15 PM
benebob's Avatar
How would you know? The tranny temp idiot light comes on at 270 degrees. Anything over about 195 is bad for a transmission and it can take quite some time for the problems to surface.
Old 10-12-2005, 01:21 PM
Whoru465's Avatar
The name's...
I know because there were no shift problems and my fluid was clear and pink, not burned. Don't need a gauge to figure that out. The fluid continues to remain in good shape. Any other questions I can answer?
-Mike
That's right...
