Old 10-04-2005, 07:08 PM
shotgunslade's Avatar
Chike:
I went back and re-read LAN's thread on the Stage2v4 chip. Looks like I misread it the first time. Looks like there are further gains to be had by changing to the Impreza FPR. So, that'll be my next mod, along with fixing the coolant leak for track days next spring. Thanks for pointing that out.
Old 10-04-2005, 07:26 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Originally Posted by shotgunslade
Chike:
Correct. The Impreza fpr should be your next upgrade. Are you into drag racing at all? If so, got to your local 1/4 mile track and do some runs. As you keep modifying your car, you can gauge improvements in hp from how much your trap speed increases.
-Chike
2006 Steel Gray WRX TR (sold)
Old 10-04-2005, 08:19 PM
Chike:
Will give it a try
Old 10-06-2005, 05:14 PM
Chiketkd's Avatar
Chike:
Will give it a try
Shotgun,
You have a PM.
Old 10-07-2005, 03:41 PM
Originally Posted by benebob
Stock brakes are just fine! I'd say we're stopping around 145-150ft from 70 with absolutely no fade and our ancient rotors aren't warped in the least.
That may be true but how many times can you do this in a row? Imagine doing nothing but back to back 1/4 mile races except HARD on the brakes and maybe even on the gas slightly while left-foot breaking.
I'm sure all our cars are good for 1 HARD stop.
Old 10-07-2005, 04:56 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Well with both Hocrest and I driving the car in the same heat sometimes we haven't had an issue. Got the brakes so hot that the rear seized on a day that it got driven about 40 miles on a track. Granted we don't have metal in our pads like most people. I know that if we had slotted or cross drilled we probably would've cracked 'em by now. I'm not a huge fan of left foot braking. It doesn't seem to work when you have the equivelent of a 300hp SVX. Rear comes around a little too nicely.
Old 10-07-2005, 05:36 PM
I have Ben's drilled and slotted rotors. I did four 25 minute sessions each day for a total of about 100 miles, I would guess. In any event, it was a whole tank of gas. No fade, no issues on the brakes. On my 92 LS-L, which I had for 7 years, and about 50,000 miles, I replaced the rotors in year 5, because they had warped. Ben's set-up just feels a lot more competent in hauling the car down from speed. When I get on Route 1 every morning to go to the train station, I usually floor it and get up to about 80 to make the next light which is at a traffic circle (about 6am, so no traffic issues). Timed lights, you know. With the stock pads and rotors, it just wasn't confidence inspiring, to pull down from 80 to about 5, standing on the brakes. The current set-up feels great. At the track, also, it afelt good throughout the entire day. They haven't cracked yet.
Old 10-07-2005, 05:56 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Chike:
Don't be surprised to find the coolant is actually coming from the overflow tank. What you've described is exactly what happens to my car when autoX'ing on really hot days - before I put a hose clamp on where the tube from the top of the radiator attaches to the overflow tank. When things get really hot the fluid will blow out of the tube and onto the frame rail and into the driver's side wheel well. Under normal driving conditions everything stays dry, as the fluid doesn't get as agitated/hot and will just go into the tank.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
