Old 09-11-2005, 01:48 PM
intellibomb's Avatar
intellibomb intellibomb is offline
wrx 5spd driveshaft lengthening Q???
hello
my question is,
what must i do to "lenthen" the driveshaft to make the 02 wrx tranny fit?
i have read all about many different ways to do this
via spacer
or actually lengthening.
i was wondering if anyone knew
a) where i could get the proper spacer or a cad file for one so i could have one machined
or
b) a diagram of dimensions or whatnot for the act of actually having a piece added to the driveshaft to make it fit
thanks for any input!
i
Old 09-11-2005, 02:32 PM
Manarius's Avatar
Manarius Manarius is offline
I would highly suggest you have a new drive shaft made. Lengthening can cause an in balance in the shaft which will make your car all wacky.
Note: I speak from experience.
-Jason
-Obi Wan Kenobi
Old 09-11-2005, 03:40 PM
mbtoloczko's Avatar
sans SVX
I haven't heard of anyone use a WRX driveshaft. Everyone I know has either used the SVX driveshaft or used the Legacy Outback driveshaft. Not sure if the WRX driveshaft will fit because the center carrier bearing mount may not line up with the mounting holes on the SVX.
Certain years for the Legacy Outback driveshaft almost bolt right up to a 5MT SVX. The only mod required is the that carrier bearing mounting plate from the SVX driveshaft should be moved over to the Legacy Outback driveshaft. If the SVX driveshaft is used, its only necessary to lengthen the front half of the driveshaft. If the job is done correctly by a good driveshaft shop, there are no misbalance issues.
Mychailo
Visit my locker
Old 09-11-2005, 07:03 PM
Manarius's Avatar
Most people do 5 MT swap with 1st Gen Legacy's. I don't know if our drive shafts will fit a WRX tranny.
-Jason
-Obi Wan Kenobi
Old 09-11-2005, 07:09 PM
mbtoloczko's Avatar
sans SVX
Lengthen the front half of an SVX driveshaft by 2", and it fits perfectly with a WRX 5MT. Several people, including myself, have done it.
Mychailo
Visit my locker
Old 09-11-2005, 09:27 PM
thundering02's Avatar
Giong back to the beaters...
Would it be acceptable to use a spacer?
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
Old 09-11-2005, 10:07 PM
mbtoloczko's Avatar
sans SVX
Its not possible to put a bolt-on spacer in the front half of the driveshaft. Small Car uses a spacer with their kit, but it goes between the rear diff and the driveshaft. This moves the center carrier bearing forward away from the mounting holes on the car. Small Car has an adapter bracket to go between the mounting holes and the repositioned carrier bearing. Its not such a great solution.
Mychailo
Visit my locker
Old 09-12-2005, 02:44 AM
yes, i would agree, the idea of having a nice, machined one piece extension does sound better than a spacer that must have the carrier bearing repositioned and whatnot
what should i expect to pay to have a driveshaft shop lengthen mine?
Old 09-12-2005, 05:38 AM
Lengthening the front section of the drive shaft is the best solution, but the driveshaft out of a 5-speed legacy can be used (with little modification).
And if you decide to go with the spacer, I have a CAD file of it, I can send to you.
Old 09-12-2005, 10:19 PM
ooh
so a legacy 5spd driveshaft can be used.
good to know
so, what would be the "little modification" that would be needed to make it fit?
and also, what years should i look for?
thanks so much for all the help.
Old 09-13-2005, 05:51 AM
ooh
good to know
I think the one I used came off a 97.....
I had to switch the center carrier bearing mount from the svx one onto the legacy one to have it mount up correctly to the SVX (but I've been told some years bolt right up) and I had 1/2" taken out of the front section, but Paul just ground down the tin guard some, on the back of the tranny (bell shaped cap around the output) and it worked fine stock length.
Old 09-14-2005, 02:02 PM
SilVerXtc
I originally used the stock SVX driveline with the small car spacer. I didn't like it. So I swapped in a legacy driveline. I Only had to cut 1/2" off the front cup of the driveline with a hack saw. Also where the carrier bearing bolts up the holes where a different width. I just removed the rubber bushings on the carrier bearing mounting holes and used washers to get the right width. I'm happy with the performance of the Legacy driveline and haven't had any issues.
Old 09-14-2005, 04:26 PM
cool
thanks for the help!
if i still am lost when it comes time to do the swap i will be sure to ask lots of Qs
thanks again!
