Old 06-26-2005, 01:51 AM
rvnmaniac rvnmaniac is offline
Formerly known as henryrace@hotma
Damn Pot Hole
Well i didn't see it fast enough to avoid it. Hit a pot hole Saturday, more like a ditch in my opinion, anyway the tire was destroyed and rim was bent. So since i need another tire and rim i have some decisions to make. Since it's recommended to keep all four tire's tread depth the same on an AWD vehicle looks like i'll be ordering 4 new tires. These only had about 7k miles on them. the next decision is to find a another RH/Passenger side rim or just purchase 4 new rims while i'm at it. I was thinking about maybe replacing the OEM rims some time in the future but not right now. Motorsport seem to have a nice price and selection on rims for the SVX.
I've seen some rims at other sites mentioning off sets. What is this referring to? I'm assuming certain rims need to be off set to fit certain vehicles, at least it sounds good. How does that effect mounting or anything else?
DECISIONS DECISIONS. I have to do something soon i can't and will not ride around with just the doughnut.........
HENRY
HENRY
92 SVX Claret(No More)
12 Camaro ZL1
89 Yamaha FJ1200
07 Yamaha FJR1300
"GO RAVENS"
Old 06-26-2005, 03:25 AM
KCROGUEDOG
u can some how get the city to pay for damages if the same pot hole was complained about and supose to be fixed. i would check in to it. that is what ive been told by a person that worked fixing those bastards.
Old 06-26-2005, 08:13 PM
1992SVX 1992SVX is offline
how many miles do u have on the tires u have. if under 10-5000miles depending on tire. your ok to just get one tire with new rim. as long as there is not much thread difference. i work at a tire shop
1992 pearl svx (given away)
Custom Cold Air Intake
Stage1 Shift Kit
Brembo Cross-Drilled/ Slotted Rotors. Front and Rear
4.44 gears
now in better hands of svxfiles
Old 06-26-2005, 09:03 PM
If i'm readiing this right if i have less than 10K miles and it's probaly close to about 7k miles, it shouldn't be a big problem putting one new tire on vs the other 3 being used?
HENRY
HENRY
12 Camaro ZL1
89 Yamaha FJ1200
07 Yamaha FJR1300
"GO RAVENS"
Old 06-26-2005, 09:44 PM
SubaSteevo's Avatar
No longer blue member
HENRY
With only 7k difference, you should be perfectly fine.
If you want to be extra safe, put the new one on the front and put a little more air in the one on the other side (maybe like 2psi).
-Steve
01' MSM Lexus IS300
Old 06-27-2005, 07:45 AM
Actually i just rotated the tires so it is the front tire that needs replacing. That would definitely save me some funds. Even though i want to upgrade to 17" rims but wasn't expecting to do it at this time. Just purchased the car last March and have already done the following:
Mar 23 2005 = Front Rotors – frozenrotors.com
Mar 23 2005 = Inner Tie Rods – Belair Subaru
Mar 24 2005 = Front Pads AKEBONO #ACT333 – rock auto
Mar 25 2005 = License Frame - AUTO BARN.COM INC.
Mar 28 2005 = Tie Rod install & Alignment – Belair Subaru
May 29 2005 = (58,910 miles) = 60K maintenance - (replaced PVC valve, air, oil, and fuel filters, replaced spark plugs, all lubricants, coolants, and brake fluids, replaced timing belt).
=Replaced the crank case seals and o-rings. Installed new water pump, re-sealed the oil pump, new accessory belts, and replaced the power steering pump o-ring. Sealed the rear lights with silicone for water leaks in the trunk. Replaced the control switch for the outside mirrors, installed new brake pads front and rear.
Jun 23 2005 = Genuine Austrailian Front seat sheepskin covers
So i don't really want to put more money into the car just right now. The car runs like a whistle. Anybody have a right side rim in GOOD shape. If not i'll probably order one from Motorsport...........
HENRY
12 Camaro ZL1
89 Yamaha FJ1200
07 Yamaha FJR1300
"GO RAVENS"
Old 06-27-2005, 10:09 AM
mikecg's Avatar
mikecg mikecg is offline
I got an extra floating around my parents shop. I'll see what side when I go there this weekend. I can even arrange to meet you just on the Eastern Shore side of the bay bridge.
Old 06-27-2005, 11:49 AM
I may be able to get a 97 OEM rim, i should know before Friday. I'm aware the sizes are the same how about the rim colors, 97 vs 92 SVX rim. Are they both the exact same Silver or a slight difference between the two.............
THANKS
HENRY
12 Camaro ZL1
89 Yamaha FJ1200
07 Yamaha FJR1300
"GO RAVENS"
Old 06-27-2005, 12:28 PM
SubaSteevo's Avatar
THANKS
92s are darker
-Steve
01' MSM Lexus IS300
