Old 06-05-2005, 06:01 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
So the solution would be to find a TCU from a FWD SVX?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 06-05-2005, 08:27 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
-Bill
i would think that an Impreza would work as the wiring harnesses are so similar on the tranny end but haven't gotten one yet to try it. If not doesn't Jesse have a FWD parts car lying around?
Old 06-05-2005, 07:32 PM
SVXelerator SVXelerator is offline
Frequent User
Mr. Benebob,
From the appearance of Mr. Green1995SVX's locker, he has a multitude of SVX parts in some sort of building with no windows. I hope he does not also live there!
Maximum acceleration, maximum lateral g-force...it can be done, it just takes time and $$$
Old 06-06-2005, 11:51 AM
Originally Posted by oab_au
Thats a signal that the ABS pulls a low on, to tell the TCU, what its operating, and to go back to 3rd. The wire thats been disconnected from the ABS, would stay at a high, so it should not be causing the problem.
I am pretty sure that all 4eat will change at peak rpms to save the engine. That change point is probable different for the different engines.
I remember saying a long time ago, that the shift pattern in the TCU of the smaller engines may have a better shift timing than the SVX. Because they don't have as much power to waste, the TCU would do a faster, harder change to maintain velocity.
Thanks for the advice on whats causing this problem. Lot's of 1.8 Imp's in the yard to pull out of... Hopefully the wires match????
The 4eat in my 97 Legacy won't shift if I have it in 1st, but rather it will stay in gear and bounce RPMs at Redline (same thing if I have it in 2nd, it will shift from 1st to 2nd, but won't shift into 3rd. I'm guessing the same story for third, but I've never redlined with the selector in third)
Old 06-20-2005, 09:19 AM
benebob's Avatar
The woes continue. Doesn't like shifting out of first every. Sometimes it'll go to second, other times right to 3rd or 4th. We even plugged a Legacy FWD tcu in it and I think it ran worse. Oh well off to the yard to pull a nice $30 awd tranny this afternoon.
