Old 05-31-2005, 09:45 PM
RFL
Wheel Bearing Consequences
Hi all,
3 of my wheels are making the dreaded "snow tire" roar. Not too bad below 65 mph, but pretty loud at 70. My question is, how long can you drive this way? What are the signs of bearing failure? My dealer wants $375/wheel to change them, is this about right? I also have a leaky power steering rack, $1100 to replace at the dealer. It doesn't leak enough to see at the dipstick, so I'm inclined to live with it. Any advice?
Roald Lutz
92 Claret SVX
103,000 miles
Old 05-31-2005, 10:32 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
The longer you drive it, the more expensive it wil get. There is no telling how long it will last. I had one last many thousands of miles when it got loud. I also had one that only lasted a couple hundred before it got significantly worse.
It will get more expensive because you may have to replace the housing as well. $375 per wheel is not a bad price at all. ~$100 for parts alone.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 05-31-2005, 11:04 PM
Is it bearings or tire noise? I been in cars that I thought it was wheel bearings and when the tires were changed, it got quiet! Might be something to consider. One of mine (steering rack) has a leak and my mechanic said to live with a very small drip, but if it got worse, do something with it at that time. Good luck.
Old 06-01-2005, 06:04 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
I bought my own bearings for 60 dollars each. Had a local mechanic install them for 75 dollars each. The dealers estimate you got is just about right.
Old 06-01-2005, 06:16 AM
dcarrb dcarrb is offline
If you do indeed have three bearings going bad, you'll know soon, because if you keep driving it, you'll need hearing protection. Mine sounded like a 55 gallon drum half-filled with marbles, rolling down a hill.
good luck,
dcb
Old 06-01-2005, 08:58 AM
RFL
Wheel Bearings
Thanks all,
I should've realized the housing could be damaged by ingnoring the bearings. I'm going to get 'em changed.
Old 06-01-2005, 09:12 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Dealer?
Which dealer provided the estimate? Galles & Davis? Or the other one? Just curious in case I need to have it done and don't do it myself.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 06-01-2005, 11:34 AM
RFL
Dealer
Garcia Subaru at Lomas & Pennsylvania.
They seem pretty good, had them change my transmission fluid and fix the air conditioner. Somehow, they got confused and changed my oil too. No charge; can't complain...
Old 06-01-2005, 03:18 PM
I also recommend confirming whether it's the bearings or tire noise. The easy way to tell is that if the sound changes when the road changes then it's the tires.
