Old 05-31-2005, 08:42 PM
rbalach rbalach is offline
Originally Posted by mysvxrocks
then one day it just went into 4th and I have never been able to get it out?? ~Dennis
U sure the manual button on the shifter is off ?
Old 05-31-2005, 09:17 PM
mysvxrocks's Avatar
mysvxrocks mysvxrocks is offline
Im REALLY addicted! CANT STOP!
Send a message via MSN to mysvxrocks Send a message via Yahoo to mysvxrocks
Well, that was the first thing I checked , however there is another thing... the button in the pic above the shifter has always been up, and there isn't a way to get it down. And the thing is, it wont shift when you hit the brake like it should, you have to push the button down to be able to shft. So I dont know if that has anything to do with the tranny not working, but its something else that i'll need to get fixed. ~Dennis
D.J. McPhee
2006 Infra-Red Ford Focus ZX3 ~ 67k
No longer SVX'n, Ill always miss them!
1995 Polo Green LS-i ~ 95k
1992 Dark Teal LS-L ~ 145k (04/91) #2231
Old 06-01-2005, 05:43 AM
MpSVX's Avatar
MpSVX MpSVX is offline
SVX...It's the only opption
I believe there is a srew of some sort the adjust the brake pedal/button release mechanism. It should be on the center console if you pop out a little insert if I remember corectly. Anyone else know what I'm talking about, because I don't rember 100%
looking for svx
former owner-
94-L 124,000(traded it when tranny went bad)
Old 06-02-2005, 01:09 PM
Matthewmongan's Avatar
Matthewmongan Matthewmongan is offline
no limitation as limitation
i paid 600 for my tranny and rear end (4.44). solved my problems in a jiffy at a good price. i cant help you with the engine tough. best bet is to chip away at it untill its working. deal with one problem at a time.
and i paid 3000 for my project car (it turned into one real quick)
Old 06-02-2005, 02:19 PM
KCROGUEDOG
hey matt off topic but did u change the 4.44 gearing yourself and how much do they usually run for? used? Outback right? can u put the whole diffy in or just gears? I have little clue but i hear it brung up all the time. Has anyone changed gears in the front one?
Old 06-02-2005, 02:35 PM
it was 600 (includes rear) used with 70k on it, svxfiles did the swap for a fee. the whole tranny is replaced as well as the rear end, only think kept from the origional is the limited slip carrier in the rear. but you could op for a svx without limited slip if you really wanted to. shifts are hard and fast (they way it should be) and its a blast to drive. i was thinking about putting a set into my old legacy after i got out of college but my sister totaled it.
