Old 05-29-2005, 09:02 AM
SVXer95 SVXer95 is offline
Word to Yo Motha
Throttle Cable Replacement
Has anyone had to replace the throttle cable before? Mine is on it's last legs and beginning to break. It is sticking and I fear that it will sever completely. I have checked out prices and it seems to only be ~$26, but I am unsure of the ease of replacement. How easy is it to replace? Easily accessable?
It appears to come through the firewall at a high position, but I have not yet looked on the inside to see where. Any suggestions are welcomed. Thanks.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 05-29-2005, 02:57 PM
mbtoloczko's Avatar
sans SVX
If you can do Koni strut inserts and springs, I think you'll be fine with the throttle cable. Just do it. :-))
Mychailo
Visit my locker
Old 05-31-2005, 07:55 AM
Word to Yo Motha
I should hope I can figure this out.
I checked it out and it doesn't look bad at all. I am just wondering how the hell I am going to fit myself into that area. I think I am going to have to go on a diet to do this repair!
I couldn't seem to fit my hands or eyes behind the pedal assembly to determine how the cable comes out. I am just going to pull the whole thing. Good thing the part is cheap! I just wish it would get here a little quicker. I have to drive a Civic the whole week!
Maybe I will drag race it through a school zone since it is so fast.....
Collin
1995 L AWD
Locker
Old 05-31-2005, 08:20 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Before you pull the cable out, tape the new cable to the end of the old one and use it as a snake to pull the new one through.
Old 06-01-2005, 03:00 PM
I think he's referring to the entire assembly and not just the cable that runs through it.
I haven't done this job but if I were to guess I would rate it a 3 out of 10 where 10 is a 5MT swap and 1 is filling your tank with gas.
