Old 05-17-2005, 03:53 PM
LarryGreen LarryGreen is offline
mean.green.machine
What's OBDII Code 0141 Mean?
My check engine light on my 96 has come on, and the OBDII code is 0141, which is "O2 Sensor #2, Heater circuit #1, bank 2" or something like that. I changed out both 02 sensors and the check engine light still comes on. Any ideas of how to fix it? Thanks.
Old 05-17-2005, 05:19 PM
Have you reset your codes?
Try leaving the battery cable disconnected overnight.
Old 05-18-2005, 06:09 AM
mean.green.machine
I have an OBDII diagnostic code reader which also enables me to erase the codes, but the check engine light keeps coming on every few days or so. So I'd like to fix whatever the problem is.
Old 05-18-2005, 09:20 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Disconnecting the battery is rarely a good idea. If there are a multitude of codes I might reccommend it before replacing the ECU, but that's about the only instance.
Notice that the code description stated 'circuit'? That indicates that it probably isn't the sensor itself but rather the wiring/connectors.
