Old 05-06-2005, 09:59 AM
vg30dett1990 vg30dett1990 is offline
new guy with a smoking problem from exhaust
HI I have been lurking for awhile but now i am in a pickle. I have a 1992 LsL that smokes like a beast out of the exhaust. I took the manifold off cleaned it and installed a new pcv valve and vacume lines and it still smokes I also changed the oil and spark plugs and ran codes, the dip stick pops up too. There is also a popping sound comming from the exhaust when acclerating. Any ideas?
Old 05-06-2005, 10:14 AM
Weasel 22
check your coil packs..sounds like your baby is missing..you did the plugs etc..so your list is dwindling
Old 05-06-2005, 10:17 AM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Cool
do a compression check on the motor. sounds like the rings have had better days or your cam belt jumped out of time which would explain the popping sound.just some ideas.
Old 05-06-2005, 10:46 AM
What are the compression numbers for the cylinders? Also the car runs real smooth and drives smooth to no hesitation i also did a 4.11 swap also if that helps.
Old 05-06-2005, 01:07 PM
Does your check engine light ever come on?
Old 05-06-2005, 01:20 PM
nope the light never comes on. I just got done checking the timming and that looks good. But she quit smoking after i checked the timming. I am going to let her sit and see if it starts to smoke again
Old 05-06-2005, 02:04 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Welcome to the site. Sorry to hear about your troubles and I hope you figure the issue(s) out soon.
-Chike
P.S. Love your username btw. I used to own a silver '90 300ZX TT. Those cars rock!!!!
2006 Steel Gray WRX TR (sold)
Old 05-06-2005, 05:52 PM
Well I drove the car all evening it didnt smoke but only at start up. It use to smoke all the time . I changed the oil over to synethic could that be my problem?
Old 05-06-2005, 06:15 PM
Weasel 22
synthetic doesnt burn quite as easily as dino oil..it looks as if you have oil bypassing your rings...
Old 05-06-2005, 06:56 PM
THAWA
What color is the smoke. That can tell you a lot more than just arbitrarily fixing things.
White = Coolant
Blue = Oil
Black = Fuel
Old 05-06-2005, 07:47 PM
It is kind of hard to tell the color it smells like burning oil but it looks greyish in color my coolant level dosent change and my temp gauge is reading normal. Would a crack in the intake duct cause this problem? I found one in the bottom next to one of the lines that run into it, also does anybody know where I can get anthor one to replace it?
Old 05-06-2005, 08:15 PM
THAWA
Is there a leak in the PCV system?
Old 05-07-2005, 06:25 AM
I thought it could be a leak in the system. So i took my air compressor and blew air through all the line to see if any were clogged or anything and i could here valve piston move everytime i shoot air through. I did fine one leak. I fixed it and it didnt change anything.
