Old 05-02-2005, 12:29 PM
SnowPlow
Hawaiian car hates cold!!
I have just moved from Hawaii to North Dakota, and my SVX as well. My old name was SVX-HI, I may have posted a couple times a few years ago, but have sense not been on the site for awhile (got married ie busy). I was mostly and still am more of a browser of threads.
When it first arrived in the great white north the temps were a nice and mild 50s-60s F. This last week it got down in the upper 20s-30s and I noticed it makes a loud screeching noise when started (sounds like the belt or somthing powered by the belt) If I gun the engine, or wait for it to run for a couple minutes, it goes away. It makes the same sound when turning my wheel when I first back out but that goes away by the time I make my next turn.
I just want to know if this is it being pissed off in the cold, and what can I do to prevent it?
Its real embarrassing to sound like a junker when I back out of my appartment or new job.
Sorry for the long post, but I'd appreciate your help
Old 05-02-2005, 12:38 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
Sounds like belt squeal. How is the tension on the belt? Does it look dry-rotted or cracked? If it isn't the belt, a new power steering resevoir o-ring may help. Is the fluid leaking at all?
What kind of oil are you running?
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 05-02-2005, 12:49 PM
SnowPlow
The belt is only 1 year old. The steering I just had replaced 6 mo. ago, the whole rack and pinion or what ever this car uses. It had to be done twice actually because it didn't "self bleed" like it was supposed to. Maybe there is a leak, I'll check.
Is this caused by lack of fluid you think?
oil is 10w30...I think. my parents picked the car up from the port and drove it half way from Dallas to me, they did the oil change, probably just recommended oil (for Texas).
Old 05-02-2005, 07:37 PM
Chris's Avatar
Chris Chris is offline
Founder / Administrator
Send a message via ICQ to Chris
sounds like the alternator belt to me. Either bad or too loose. If the sound doesnt go away, it might be a tnetioner pulley bearing, but Im betting belt.
-- Chris
Founder/Administrator SVX World Network
ECU Tune (stage 1), PWR (prototype aluminum radiator)
Amateur Radio - General Class - K7SVX
#1 92 Teal LSl 246k (Dedicated SVX Race Car, now with 4.44 speed)
#2 92 Teal LSl 125k (Retired, car rescued from a field of weeds)
2007 Impreza 2.5i Special Edition, Obsidian Black Pearl (Daily driver)
2001 Dodge Ram 2500 quad cab, Cummins turbo diesel 4x4 (race car & RV hauler)
1985 Honda VF500 Interceptor (fair weather fun commuter)
Going on 11 years of NHRA bracket racing
NHRA Div 6 Car/Driver # T654 (site being rebuilt, new name is www.teamsvxracing.com)
2000 1st Place Club Challenge Series
2002 3rd Place Season Track Champion, Import Racing (Firebird Raceway)
2003 4th Place Season Track Champion, Import Racing (Firebird Raceway)
2003 1st Place NW Regional Import Shootout (July 5th)
2004 1st Place Club Challenge #1 (Firebird Raceway)
2004 1st Place NHRA "King of the Track" race
2004 NHRA Gold Cup 2nd place season win
2004 Import/Sport Compact 3rd place season win
2004 Division 6 Summit/ET NHRA Race of Champions finalist competitor (Mission, BC)
2007 1st Place Import Survival #3
2007 1st Place Track Champion Import Summer Jam (Wild Street Class)
2007 1st Place Import Survival #5
2008 Club season 1st place win, Club Champion
2008 2nd Place Season Import Final.
2008 Division 6 Summit/ET NHRA Import Finals (Woodburn, Or)
2009 2nd Place Import Summer Jam (Wild Street Class)
2010 1st Place Club race #2 - 1st place Sport Compact race #1 & #2
Old 05-03-2005, 01:25 PM
I think he meant what kind of oil is currently in your power steering system. There's 2 legitimate answers to this question: Power Steering Fluid or ATF (tranny fluid). Subaru recommends ATF (Dexron II or higher).
If 10w30 (engine oil) is actually being used then get it out of there.
Old 05-03-2005, 01:40 PM
SnowPlow
I hope its the belt
Oh in that case its what ever the dealership put in when they did the work on my power steering
Old 05-03-2005, 04:41 PM
thundering02's Avatar
Giong back to the beaters...
My vote is for the belt as well and even new belts can squeel if impropperly done
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
Old 05-03-2005, 05:30 PM
It is most likely the belt. They slip more when cold. As they run and get warm, they get a better grip.
Most likely the tension is not set right on your power steering belt. It could be the alternator belt either, as Chris says, but if it sqeeks more on using the steering, most likely the steering pump belt. Just get whichever is sqeeking tightened to the correct tension.
And the oil in your power steering reservoir should be pinkish colour if it is the correct ATF Dexron II. If it's not, suck it out of there, and put in the correct stuff.
Old 05-03-2005, 05:31 PM
And I forgot to say, welcome to the Forum.
Old 05-04-2005, 12:49 PM
SnowPlow
Thanks everyone, I'm going to try to correct tension on the belt, but how do I know if it is tight enough (aside from it flopping around when I grab it). Do I just tighten it until the noise goes away, is there a risk of over tightening?
Dirk
Old 05-04-2005, 04:25 PM
If you can't twist the belt vertical with your fingers then it's too tight.
